Old 07-19-2010, 01:00 AM   #1
chase1873
chase1873's Avatar
1969 C10 short box step side.... my first build.
Trying to do a full frame up restore on this awesome 1970 stepper... I paid $900 for the truck with a v6, 4 on the floor, and 12 bolt rear end. I was told it has 2in drop spindles up front (I believe he meant springs), 2 in drop springs in the back, and oldddd american racing rims. Lots of potential. Here are a few pics.
chase1873 is offline   Reply With Quote
Old 07-19-2010, 02:58 AM   #2
67chevy1series
67chevy1series's Avatar
Re: 1969 C10 short box step side.... my first build.
well im glad to be the first to say welcome and it happens thats for the future have fun
67chevy1series is offline   Reply With Quote
Old 07-19-2010, 12:35 PM   #3
chase1873
chase1873's Avatar
Thanks 67, I hope you enjoy my build, it might me a while....
So I got some stuff done this Sunday I hope to have it down to the Chassis by next week... pictures
Old 07-19-2010, 12:40 PM   #4
1LoC10
Insert Title Here
1LoC10's Avatar
Looks like it nice truck, do you know what parts were used to convert it to disc and still keep it 6 lug?
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-19-2010, 02:36 PM   #5
chase1873
chase1873's Avatar
It still has drum breaks, but i was looking into converting it a few companies make kits heres one....
http://www.ecklerstrucks.com/chevy-t...1963-1970.html
Old 07-19-2010, 03:56 PM   #6
1LoC10
Insert Title Here
1LoC10's Avatar
where did you find 2 inch drop spindles for drums
BOBBY
_69 SWB_
Old 07-19-2010, 04:02 PM   #7
chase1873
chase1873's Avatar
Im not sure who makes them, they were already installed when I bought the truck... or so i was told anyways maybe he ment springs.... Ill have to do alittle measuring when I get a chance.
Mike
1970 C10 swb step side... needs everything.
Old 07-20-2010, 02:33 PM   #8
chase1873
chase1873's Avatar
pictures say 1000 words
Mike
Old 07-20-2010, 03:30 PM   #9
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice progress! What kind of plans do you have for your build?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-20-2010, 08:42 PM   #10
chase1873
chase1873's Avatar
on my list is 4/6 drop, some american racing rims, 12 bolt posi rear end, and a 6 speed bolted up to an LQ9. I want to paint it orange but have not pick an exact color yet, and ill find some nice bucket seats out of someones smashed Cadi. Should be pretty mean if I can pull it all off..
Mike
Old 07-20-2010, 08:53 PM   #11
Dieselwrencher
Sounds pretty cool!
Ryan
Old 08-11-2010, 09:43 PM   #12
chase1873
chase1873's Avatar
some more progress... I sandblasted a small section of the frame and under coated it. pictureeessss
Mike
Old 08-11-2010, 10:22 PM   #13
Dieselwrencher
That looks much better. Nice job.
Ryan
Old 08-12-2010, 11:47 PM   #14
chase1873
chase1873's Avatar
thank you, the process was a lot simpler than I expect it just took tlc.
Mike
Old 03-13-2011, 04:38 PM   #15
chase1873
chase1873's Avatar
progress
Mike
Old 03-13-2011, 06:43 PM   #16
RCbowtie69
RCbowtie69's Avatar
Looking good,keep pictures coming
RCbowtie69 is offline   Reply With Quote
Old 03-13-2011, 07:06 PM   #17
chase1873
chase1873's Avatar
So I ran all the numbers on the truck an it seems the previous owner didn't know much about the truck.. The frame vin revealed the truck is actually a 1970** it had a 1983 4.3V6 and a 4 Speed Saginaw transmission.
I plan to get the truck down to the bare frame over the next week and begin the long process of sandblasting and painting it.
Mike
Old 07-31-2011, 08:32 AM   #18
chase1873
chase1873's Avatar
slow and unsteady progress... I have it down to just the frame, theres a picture of a section after being sandblasted, and a few pictures of an organ doner blazer I just picked up. working on a very tight budget
Mike
Old 08-08-2011, 08:47 PM   #19
chase1873
chase1873's Avatar
heres my question.. I plan to reuse the A-arms just blast them and repaint them, what is the best route to take in regards to the bushings??? they seem fine, most of the front end parts had been replaced fairly recently. Should I get new bushings, new shaft and bushings, or just clean them up and put them back in??? any help is appreciated.
also, on the passenger side there is a bracket that is riveted to the crossmember. This bracket connects the upper A-arm the the crossmember and the frame. It's has been structurally compromised from rust and I want to replace it... not sure what it is call or where i can find one...
any ways attached is a Sneak Preview of the frame, its almost done, man it was alot tougher than I thought it would be to get her all sand blasted and under-coated. I even borrowed a buddies tow behind inline four cylinder compressor to try and make the process go along a little smoother but it was only pushing about 65 psi constant... miserably slow... anyways, the front cross-member is out and all the suspension components are pretty much disassembled. I have a shopping cart full but im waiting for some input before I pull the trigger...
rear trailing arm bushing
rear drop shocks
rear shock re-locator brackets
rear springs- 6 inch drop
front drop shocks
2- Tie rod ends (inner)
2- Tie rod ends (outer)
2- Tie rod adjustable sleeve
Pitman arm
Idler arm
2- upper ball joints (bolt in)
2- lower ball joints (bolt in)
2- Control Arm shafts (upper)
2- Control Arm shafts (lower)
Drop Spindles 2.5 inch
Mike
Old 03-06-2013, 05:55 AM   #20
chase1873
chase1873's Avatar
So guys, my not so build, build may be coming to life shortly. I am graduating this May with a B.S in ME will finally have some time away from school and internships to work on this sexy stepper.
Here are some photos of how she sits. Quietly waiting for life to be restored.
Mike
Old 03-06-2013, 07:52 AM   #21
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If the control arm bushings are tight, I'd leave them be. No sense spending money to replace good parts. With the quality of parts we're all getting nowadays, replacements might even be a step backwards. If you keep them greased periodically, steel control arm bushings virtually last forever.
Old 03-06-2013, 07:55 AM   #22
Xeen
Xeen's Avatar
Did you get rid of the the Blazer already and is it 2wd? Alot of guys are taking the front suspension and rear axle out of the 73-87 and swapping them into the 67-72 trucks. That will take care of your 5-Lug conversion and give you front disk brakes, win/win.
I'm confused are you putting a Gen 1 small block or a Gen 3 Vortec in the stepper?
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 03-06-2013, 09:12 AM   #23
chase1873
chase1873's Avatar
I have already purchased new control arm shafts from NAPA, but i will look more closely into the current ones. Im sure NAPA will take a return if I feel necessary.
I have been a little bit all over the place with my plans for this build. Young and inexperienced are the causes of this. I bought the blazer with the intent on getting a cheap drive train in the truck, but ended up selling the 350, 700r4, and np205 for more than i paid for the blazer. That coupled with the scrap metal price put me well into the green. Consequently, i went out and bought the LQ4 pictured above.
The LQ4, sm456, and 12 bolt rear end will be the drive train. I have all the front ad rear suspension parts as well. Just need some time to start getting it together. Cpp 2.5 drop spindles and NAPA hub assemblies from 73-87 gms.
Mike
Old 03-06-2013, 12:17 PM   #24
mcbassin
Still Learning
mcbassin's Avatar
Totally agree with Tex on this one.
mcbassin is offline   Reply With Quote
build, c10, low, lowered, step side
