Old 08-13-2010, 06:34 PM   #1
JimZ
JimZ's Avatar
LS3 in-tank fuel pump recomendation
Can anyone respond with information or refer to a thread regarding an in-tank fuel pump for an LS3 engine? I have a 65 fleet side project with an aluminum, baffled, efi, relocation fuel tank, purchased from CPP. I prefer using an in-tank fuel pump and sending unit. The LS3 has a returnless system and requires 60 psi constant pressure and 40 gph delivery. Anyone doing the same thing now with success? Part numbers and manufacturers are appreciated. Thanks for any help and thanks for this forum - I'm a newbie.
JimZ is offline   Reply With Quote
Old 08-13-2010, 09:01 PM   #2
clinebarger
Re: LS3 in-tank fuel pump recomendation
I went to CPPs website & chould not find anything on it? Did they send you any info about what sender to run? I whould run a Walbro 255 lph (67 gph) fuel pump with whatever sender fits CPPs tank.
Universal intank fuel pump http://www.summitracing.com/parts/VPN-GSS341/
This one comes with a "pigtail" & a "sock" for the pump http://www.summitracing.com/parts/VPN-GCA758-2/
For a fuel pressure regulator, A 99 Corvette fuel filter is a fuel pressure regulator & a fuel filter. http://www.summitracing.com/parts/ACF-GF822/
clinebarger is offline   Reply With Quote
Old 08-13-2010, 10:41 PM   #3
JimZ
JimZ's Avatar
No, no info with the tank, but thanks for your information. I'll take a look at it. I even called the engine supplier, crateenginedepot.com and they could not make any recommendation. They knew there were some after-markets out there but couldn't tell me what. Tried looking into a late model corvette pump, but they run two because of a split fuel cell. Not sure if one is just a feeder and the other pumps to the engine? Thanks again.
Old 08-13-2010, 11:28 PM   #4
mac72
Jim,I have all my info for pump selection at work. Ounce you do the bhp math it will tell you exactly wich pump you need.I will get it tommorow
Mac
mac72 is offline   Reply With Quote
Old 08-14-2010, 01:49 AM   #5
JimZ
JimZ's Avatar
Okay, thanks. I'll look for it tomorrow.
Old 08-14-2010, 10:31 PM   #6
mac72
Jim,Here's some info for you.This is not the calculator I used but it should work.Keep the brake spec. fuel consumption at .55.The horsepower rating needs to be actual, not what your shooting for.I'll try to remember to compare it mon. when I'm at work.
Old 08-14-2010, 11:06 PM   #7
MONTEZ
I second the walboro 255. They are the only one MAST uses for their fuel kits. I know you wont have any problems with it.
Here is the one I'll be using. We have pretty much the same set up. I'm running the L92/6L80e set up. Good for 750HP. Doubt you'll break that.
http://www.mastmotorsports.com/2010/...Systems&id=129
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 08-14-2010, 11:47 PM   #8
JimZ
JimZ's Avatar
Thanks, I'll check it out.
Old 08-14-2010, 11:51 PM   #9
JimZ
JimZ's Avatar
Was there supposed to be an attachment or something? Thanks.
Old 08-15-2010, 11:04 AM   #10
mac72
Jim once your on the page scroll down a little & just type in the numbers
Old 08-15-2010, 11:14 AM   #11
mac72
I just scrolled back & realized I didnt post the link LOL. Here you go
http://www.eastcoastrollingthunder.c...r/finject1.htm
Old 08-15-2010, 11:17 AM   #12
mac72
Guys fuel pump requirements are diff. for every horespower rating,type of use etc..,I'ts not good to just guess.There is nothing wrong w/ a 255 it's what i'm using.The guys at Mast motorsports are using the same mathmatical equations as the link I posted.Now you know how they came to that conclusion.To much pump volume has it's own host of problems!
Old 08-15-2010, 11:30 AM   #13
mac72
Here's some more info for you
http://www.autoperformanceengineerin...l/fpspecs.html
Old 08-16-2010, 02:32 AM   #14
JimZ
JimZ's Avatar
Okay, thanks for the links. Very helpful, although I thought I was going blind (or crazy) for awhile. Thanks for the help.
Old 08-16-2010, 03:13 AM   #15
99-2door
99-2door's Avatar
Stock LS3, use a Walbro 255 and a vette regulator. This is what S&P and many others use.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
