Been in search of inexpensive rear disc conversion
I have been searching around for the least expensive conversion from rear drum brakes to rear disc brakes that I can find. I found some relatively inexpensive brackets to mount front rotors on the rear from Ebay. I then found them cheaper on Speedway Motors.com. The brackets from Speedway may have sealed the deal for me though when I noticed a bracket for 78-up Metric Calipers. This sent me back to the Junkyard where I found a rear wheel drive 1979 Cadillac Seville with calipers which include built in emergency brakes.
When I went back and removed the calipers I noticed that the factory brackets for these calipers along with the backing plate bolt onto the end of the rear differential. I now believe I will go back and remove the factory bracket and affix it to my rear-end rather than purchase an aftermarket bracket. I need to measure the rotor too see if it can be found with the proper bolt-pattern or just use the ones from the Cadillac and have them re-drilled. Anyone have any thoughts on this idea? http://webcache.googleusercontent.co...&ct=clnk&gl=us Last edited by BHyatt; 08-29-2010 at 04:07 PM. Reason: Left out information |
![]() Join Date: Oct 2005
Re: Been in search of inexpensive rear disc conversion
I bought the Speedway kit with those brackets, hat, rotors, and the Caddy calipers. 6,000 miles and working great.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Happy to be here
![]() Join Date: Mar 2000
How well does the E-brake work? I have heard that its not that great. I also understand that you have to set the E-brake to adjust the calipers. Any input?
I have been trying to figure out how the e-brake works myself. I have noticed that a lot of the kits that are available appear to have similar/same calipers. It is sure to work better than having no e-brake at all. I figure for $24 I can figure it out.
You know how most projects are never 100% complete??? Not hooked up yet and I've heard the same about setting the E-brake to adjust for pad wear.....no problems yet. The stock cables are a little too short but I see that CPP sells extenders that may work.
I pulled the e-brake cable from the Seville when I acquired the calipers.
60-66 Nut
![]() ![]() Join Date: Mar 2007
From what I've read/heard, with those style of e-brake calipers, the e-brake need to be used regularily for them to maintain proper operation.
Has anyone else used these calipers?
Had a friend recently have a mechanic replace rotors on the rear of his Jeep Liberty that has drum style e-brake inside the rotor. His Pads just fell out when they pulled the rotor. The mechanic said the e-brake needs to be engaged every couple of months to insure longevity of the entire system.
![]() Join Date: May 2012
my kit has no ebrake, 78 monte carlo calipers and I think the rotors came off a 84 caprice...no problems in 10 years..havent missed the e-brake...like the stopping power..
Tags |
brakes, caliper, conversion, disc brakes, rear |
