Old 09-24-2010, 11:13 PM   #1
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
72 Custom/10 starting budget: 58¢
So it begins... Slow and Easy...
Finally got the truck home!!!
Wasn't shifting right on the drive home!
Today I was able to clean it up a bit (inside not the outside) and take some pictures.
The plan for the next couple of months:
1. install 700R4 (th350 still works so i'll leave it alone for now, but will install in the future)
3. clean up motor and tune up
4. brake job
5. fix turn signal lever (missing)
6. fix horn
I want it to be my daily driver.
Later on I will start on the bodywork... don't know how but I will learn!
Pictures to follow:
-- Jorge --
1972 Custom/10 LWB 350
My Build
MrClean is offline   Reply With Quote
Old 09-24-2010, 11:55 PM   #2
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Re: Project "72 Custom/10 starting buget balance: 58¢"
Size:  54.7 KBName:  2.JPG
Size:  50.7 KBName:  4.JPG
-- Jorge --
My Build
Old 09-24-2010, 11:57 PM   #3
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Size:  47.9 KBName:  7.JPG
Size:  47.5 KB[Name:  9.JPG
-- Jorge --
My Build
Old 09-24-2010, 11:58 PM   #4
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Size:  58.7 KBName:  12.JPG
-- Jorge --
My Build
Old 09-25-2010, 10:02 AM   #5
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Last two for now....
-- Jorge --
My Build
Old 09-25-2010, 10:02 PM   #6
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Transmission wouldn't shift on the way home from the PO. Posted a message to this forum, Ray told me what to do and now its shifts correctly. So glad I found this forum!
-- Jorge --
My Build
Old 09-27-2010, 05:48 PM   #7
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Re: 72 Custom/10 starting budget: 58¢
Ordered the Shop Manual, and the Factory Assembly Manual today!
Want to see what's missing on the engine and fix my turn signal, speedo, temp gauge, gas gauge, and wiper motor....
-- Jorge --
My Build
Old 09-27-2010, 08:07 PM   #8
Gobbles
Gobbles's Avatar
thats a sweet looking color, are you planning on sticking with the longbox?
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 09-27-2010, 08:36 PM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
welcome! cool truck! Any progress yet ?
John
1999 Toyota Tacoma 4x4
Old 09-27-2010, 09:02 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
welcome! Looking forward to the build
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-27-2010, 09:48 PM   #11
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Gobbles: haven't decided yet on keeping it a long bed.. but I do want to change it to silver and white (white bottom and roof) with the 67-68 chrome.
Like this one of a forum members truck that I photoshoped:
-- Jorge --
My Build
Old 09-27-2010, 10:04 PM   #12
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
As for the progress waiting for the shop books (should be here by the weekend) and going to focus on the motor first then electrical, brakes, then suspension.
After all that then comes the body (will be taking a college class for that, because I don't have a clue!)
Want this to be my daily driver as soon as I can make it safe.
Oil pressure goes way down when at idle, was told it might be the oil pump...?
Speedo, temp gage, and turn signals don't work either... seems like the list just keeps getting longer...
-- Jorge --
My Build
Old 10-03-2010, 11:20 AM   #13
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Installed new oil pump yesturday, what a difference!
Was going to do the carrier bearing also but I ran out of gas....must be getting old.
Today I'm going to mess with the door handles, both have the buttons pushed in...
-- Jorge --
My Build
Old 10-03-2010, 09:17 PM   #14
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Oil pump: Done
Door handles: Done
Before
After
Carrier Bear: Not Started (got lazy, next weekend!)
-- Jorge --
My Build
Old 10-05-2010, 12:04 AM   #15
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Working these issues now:
Empty Valve Cover Holes? HELP!
http://67-72chevytrucks.com/vboard/s...ferrerid=36201
?? Loose Shifter ??
-- Jorge --
My Build
Old 10-05-2010, 09:28 AM   #16
madmopar
This guy has got to be stopped
madmopar's Avatar
maybe its just the angle, but the bed looks extra long. Is it a Longhorn?
J P Evers
1970 4x4 LWB project: http://67-72chevytrucks.com/vboard/s...d.php?t=415134
madmopar is offline   Reply With Quote
Old 10-05-2010, 10:30 AM   #17
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
No not a Longhorn, that angle does make the bed look really long.
-- Jorge --
My Build
Old 10-12-2010, 11:18 AM   #18
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
This weekend I got a little done:
1. installed new set of red tail light lenses (both of the old ones where broken)
2. put a steel fuel filter in between the fuel pump & carb, and changed the rubber hose from carb to filter to steel line.
3. lined up my steering wheel (it was upside down & turning slightly right before)
4. fixed my turn signal problem! (installed lever that I found under the seat)
5. bought and installed PCV valve, and valve cover to air cleaner hose.
-- Jorge --
My Build
Old 10-12-2010, 01:28 PM   #19
VA72C10
VA72C10
VA72C10's Avatar
how's it running?
Keep up the good progress!
Old 10-12-2010, 02:32 PM   #20
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
It runs ok... but something is a little off... doesn't run smooth...
Haven't checked the plugs, wires, or timing yet because I want to upgrade to HEI.
So... I just ordered the Skip White HEI Distributor that some of guys here recommend and new plug wires.
Hopefully with the new distributor, wires, plugs, and timing it will run smoother!
-- Jorge --
My Build
Old 10-12-2010, 04:35 PM   #21
hgs_notes
GEARHEAD
hgs_notes's Avatar
Make sure you check all the vacuum lines and connections also. That can cause sputtering and lack of power too.
hgs_notes is offline   Reply With Quote
Old 10-12-2010, 09:02 PM   #22
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Talking Re: 72 Custom/10 starting budget: 58¢
Fixed the gas gauge!!!!
Not really... found the unplugged wire and plugged it in...
-- Jorge --
My Build
Old 11-21-2010, 07:51 PM   #23
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Got a little done:
Installed my Skip White HEI distributor last Thursday along with new plugs and wires.
Need to redo the timing because a vacuum hose was unplugged when it was timed.
-- Jorge --
My Build
Old 11-23-2010, 08:14 AM   #24
Solego
Dr. Frankentruck's Monster
Solego's Avatar
The average person would look at that, run, and go spend $45,000 on a new truck. Great job!
(I can buy a house for less than a new truck.)
I'm not prejudiced, I hate everyone.
Project SLOMO
http://67-72chevytrucks.com/vboard/s...d.php?t=430494
Solego is offline   Reply With Quote
Old 11-23-2010, 06:44 PM   #25
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
Thanks!
Just doing a little bit at a time so that I don't get overwhelmed!
On the 29th of this month I'll be signing up for an autobody class at the local college, so that I can start doing some cosmetic stuff to her. CAN'T WAIT!!!!
-- Jorge --
My Build
