Old 10-03-2010, 11:28 PM   #1
FnLow69
FnLow69's Avatar
[PROJECT] Laidout53 Part II
Time for a new frame and link setup on the Dodge. This time im going to make the front crossmember and bag mounts, aswell as Im doing a parallel 4bar and panhard in the rear with bags and hopefully a small cantilever. Going to have sway bars front and rear. This time the running boards will lay out and im going to run 28.5" wide whites (3"). If time permits im going to chop (5") and body work it with some other body mods that I'll mention later when i get there, including custom inner fenders. Also will be doing a full interior. Hope to paint it Navy blue with a medium dark red interior, and flake the motor/trans medium red as well, as long as time permits...
Anyways heres the pictures of the tear down.
Steel for the frame...( three 10' sticks of 2x4 and two 10' sticks of 2x6)
Front clip off...
Bed off...
Cab striped and ready to be removed...
Bare frame....
Bring in the frame table tomorrow and will be starting the frame this coming weekend... more to come.
Justin
FnLow69 is offline   Reply With Quote
Old 10-04-2010, 12:16 AM   #2
jwalk
What was I thinking?
jwalk's Avatar
Re: [PROJECT] Laidout53 Part II
I'll defenently be watching this one! You've got some mad skills and I like your style! Might I ask where's the '69?
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 10-04-2010, 01:11 AM   #3
FnLow69
FnLow69's Avatar
the 69' is in the next stall out of the picture...
Old 10-04-2010, 10:25 AM   #4
69CST-V
69CST-V's Avatar
Subscribed.....
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 10-10-2010, 01:23 AM   #5
FnLow69
FnLow69's Avatar
well i got started on the frame this afternoon got a fair share of it started.... hope to have the frame completely tacked up this weekend. Anyways heres the pictures from tonight.
Frame rails tapered... need to get some flat bar to cap'em...
Starting to get them in place...
More tomorrow....Enjoy
Justin
Old 10-10-2010, 09:54 PM   #6
Number98
Prestige Worldwide
Number98's Avatar
Looking good man
Subscribed!
Number98 is offline   Reply With Quote
Old 10-11-2010, 01:48 AM   #7
FnLow69
FnLow69's Avatar
Well got more done this afternoon. Got the rear section of the frame together. Heres the pictures.
Got both sides gaps filled but i forgot to take a picture of the other one.
Justin
Old 10-11-2010, 01:57 AM   #8
jwalk
jwalk's Avatar
Man this is going to be killer!!! I'm following along also!
Justin
Old 10-11-2010, 11:39 AM   #9
FnLow69
FnLow69's Avatar
thanks olskool
Old 10-11-2010, 01:11 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
Cool project....going to watch this one and push you to finish it fast so you can get back on the 69
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-11-2010, 01:25 PM   #11
FnLow69
FnLow69's Avatar
Ok I'm going to hold you too it...lol
Old 10-11-2010, 07:55 PM   #12
bigguy69
dazed and confused
bigguy69's Avatar
awesome!!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 10-11-2010, 08:15 PM   #13
FnLow69
FnLow69's Avatar
thanks man
Old 10-11-2010, 08:26 PM   #14
FnLow69
FnLow69's Avatar
Well i had to move the rear section of the frame up, aswell as i got the rear tube notched for the exhaust tips to go under. Got the frame squared and picked up the steel for the A-arm crossmember(3x4x3/16). Next is some temp frame bracing and them on to finishing up the front frame horns.
heres the pictures...
Justin
Old 10-14-2010, 07:47 PM   #15
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sweet here we go agian..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-16-2010, 01:25 AM   #16
FnLow69
FnLow69's Avatar
Well last night and tonight Ive been working on the front mustang II crossmember. Hers where im at currently...
Lower A-arm mounting holes sleeved...
Smoothed...
Spacers and ends tapered....
Welded...
Well I hope to finish it tommorrow, just need to notch were the rack goes, make the rack mounts and cap the ends.
Justin
Old 10-16-2010, 10:48 PM   #17
jwalk
jwalk's Avatar
Looks good! So how many frames have you built from scratch? Did you just one day decide to build your own? Is this something you do for a living? Sorry for the questions.... Just curious.
Justin
Old 10-16-2010, 11:08 PM   #18
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Inquiring minds want to Know .....?
ksbrktracer is offline   Reply With Quote
Old 10-17-2010, 12:38 AM   #19
FnLow69
FnLow69's Avatar
This is my third sratch built frame, the Chevy, a 28 Chevy are my other two...I don't do this for a living yet, however I wanna open my own hot rod shop one day.
Old 10-17-2010, 02:03 AM   #20
jwalk
jwalk's Avatar
Hell yeah! I don't think you'd have a problem getting customers with the work you do. Good luck!
Justin
Old 10-17-2010, 11:44 AM   #21
FnLow69
FnLow69's Avatar
thanks man
Old 10-17-2010, 01:54 PM   #22
rondog4416
rondog4416's Avatar
looking good man keep those pic's coming !!!
rondog4416 is offline   Reply With Quote
Old 10-17-2010, 11:48 PM   #23
FnLow69
FnLow69's Avatar
Thanks Ron
Old 10-17-2010, 11:53 PM   #24
FnLow69
FnLow69's Avatar
Well I got the crossmember finished today. So here are the pictures.
Ends capped...
Rack and pinion notched for clearance...
Rack mounts....
Tacked in place...
Lower control arm spacers (i didnt make these) welded in place...
And all DONE!
Justin
Old 10-18-2010, 12:04 AM   #25
jwalk
jwalk's Avatar
Much respect for doing it yourself!
Justin
