10-12-2010, 10:51 PM | #1 |
Pillar Fender Seals
I got my new dust seals and just wondering if anyone has a picture of them installed,the drawing in my assembly manual shows location but still not sure about the two small hinge pieces. pictures show the kit I have and the metal pillar sides that get stapled.
Thanks 7D2N |
10-13-2010, 09:49 PM | #2 |
Re: Pillar Fender Seals
Anyone installed these? the drawing from the assembly manual shows this application but not real clear for the small pieces.
Thanks 7D2N |
10-13-2010, 10:05 PM | #3 |
GobbleStalker Calls
Where did you get the kit from?
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
10-14-2010, 02:01 AM | #4 |
I've always wondered how do you put those big staples in? Anyway I am a ways off from trying yet! Here are some shots I took on disassembly. Don't really show alot to be honest!
1972 K2500 Long Box 400/350 |
10-14-2010, 05:27 AM | #5 |
454 MAKES IT ROAR
I did mine recently, got them at Classic Parts. Most people on here were saying that these were such a PITA to install and the end result and benefit made it not worthwhile...I tend to agree. I ended up just installing the two large pieces, there was no way I had the tools to fix those large staples so I just used the self taping hex head screws to fix them onto the metal bracket, then fitted the bracket with seals attached back to the body, but then the cut out ends that sit over the door hinges didn't line up so I had to trim them and the final holes to fix them to the body also didn't aline...the small separate pieces went in the bin were they belong
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
10-14-2010, 08:54 PM | #6 | |
10-14-2010, 08:58 PM | #7 |
Thanks Billy, that will help a bunch. I have a couple of ideas for the stapling part.
7D2N |
10-14-2010, 09:11 PM | #8 |
10-14-2010, 10:37 PM | #9 |
Dont use the staples they give you with the shields. Go to lowes or depot and get some staples to use in putting up insulation etc. The staples they send do not fit the brackets if you will look in assembly manual in the 1970 section I think there is a better diagram of the actual assembly.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
10-17-2010, 03:30 PM | #10 |
Man of Mini-Talents
I used the staples that came with the kit. I used a small drill bit to drill through the existing staple holes and into the shields. Then I pushed the staples through and bent them over with a pair of wire cutters to get the bend started, and them hammered them over. Took about 10 minutes to do the set.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
10-17-2010, 03:46 PM | #11 |
To easy huh Zoomin! At least you are around to figure this stuff out for us.
10-27-2010, 10:56 PM | #12 |
Well I finished up the pillar dust seals, thanks for the responses it helped a lot. Zoomin the way you suggested is the way I ended up doing it after a few failed attempts.
Thanks 7D2N |
10-28-2010, 04:14 AM | #13 |
Great job 7D2N. I can copy you now, I just hope my memory doesn't completely fail by the time I get to do mine!
10-28-2010, 11:50 AM | #14 |
Man of Mini-Talents
Glad it worked for you. I was tempted to blow off putting them on, but since mine had them I wanted to put it back that way. I'm not sure what good they do, but what the heck.
