Old 10-16-2010, 08:15 AM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
Question about replacing rubbers in '72 BB engine mount clamshells
I'm looking at replacing the dry, cracked rubbers in the '72 BB engine mounts that are in my '69 Stepside. I would like to use polyurethane replacement mounts but have some questions about getting the old ones out without ruining the clamshells. Do the areas circled in red below just need to be drilled out to separate the top and bottom halves? What about putting them back together - do I tack weld them back after drilling them out? Am I way off base here or what?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-16-2010, 10:49 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Question about replacing rubbers in '72 BB engine mount clamshells
As I recall. drilling is what I did. I beleive (if memory serves me correctly), that is what the Energy Suspension (polyeurithane) directions said to do.
Tom Vogel is offline   Reply With Quote
Old 10-16-2010, 01:20 PM   #3
fine69
fine69's Avatar
Just put stock ones back in. Save yourself some time.
They will last another 40 years, by that time you will probably be dead.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
1972, big block, clamshells, engine mounts
