Old 10-16-2010, 10:49 AM   #1
76/85 Truck
76/85 Truck's Avatar
Breather Question
Hello, Everyone!
I had a quick question. On my Drivers side valve cover, there is a PCV going to the front of my carb, and on the passenger side valve cover there is a plumber's plug in the hole where the breather is supposed to be. So, my question is, Should I put a breather there, or is it perfectly fine plugged? From what I've seen, you "should" have ventilation on each side. Thanks!
Rich
My first truck!! 1976 Chevy 3/4 ton Camper Special and a 1985 GMC body. Has a 350, 4 BBL Edelbrock, with a Turbo 350, and NP205 T-case.
76/85 Truck is offline   Reply With Quote
Old 10-16-2010, 11:05 AM   #2
tucsonjwt
Re: Breather Question
I think you need the crankcase breather hose going from the valve cover to the air cleaner breather element in order for the PCV system to operate properly. I just spent $43 to get the proper vent hose for my 83. Here are pics of it, but I have a big block.
tucsonjwt is offline   Reply With Quote
breather, carb, pcv, valve covers
