Old 10-19-2010, 11:00 PM   #1
srvivor71
srvivor71's Avatar
Fender Emblems
OK - so I see these nice shiny new fender emblems in the catalog and figure that this is something I can afford and, even with my limited mechanical skills, must be a snap to put in. Well I got them last week and this past Sunday, thought I'd just pop them on. Well - not so easy. If I hold the flashlight just right, I can kinda see one nut on the inside of each fender and completely out of reach of any wrench. When I bought these, I didn't expect that I would have to disassemble the entire clip to put them on.
It's a 71 GMC; the fender emblems are just ahead of the door. If anyone out there has any tips on how to do this, I'd really appreciate hearing from you.
Chuck
srvivor71 is offline   Reply With Quote
Old 10-19-2010, 11:02 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Fender Emblems
Well, they ARE easier to get off when the fender is in your lap....
Drop the inner fender and you should be able to get to them, if you can't get to them any other way.
Member Nr. 2770
Old 10-20-2010, 12:23 AM   #3
68350
68350's Avatar
Re: Fender Emblems
Drop the inner fenders or mark the bolt position really well and loosen/remove the back fender bolts(under the cowl, etc) and get enough room to change the emblems. Hope this helps
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 10-20-2010, 07:33 PM   #4
AirSpeed
AirSpeed's Avatar
Re: Fender Emblems
I just used some good epoxy on the studs of my new emblems, I roughed up the chrome on the studs first so they would grab the epoxy better. I didnt want to take a chance of messing up my new paint by wrenching around the fenders, (Im a chicken) I did the same thing on my 69 about 14 years ago and they are still there.
AirSpeed is offline   Reply With Quote
Old 10-20-2010, 08:25 PM   #5
srvivor71
srvivor71's Avatar
Re: Fender Emblems
I can epoxy the new ones on but my real problem is getting the old ones (with studs and nuts) off. I guess I'm going to have to pull off the inner fenders.
Old 10-20-2010, 10:49 PM   #6
AirSpeed
AirSpeed's Avatar
Re: Fender Emblems
I used a putty knife and a hammer to get my old ones off, I just stuck the putty knife between the fender and the emblem and hit the putty knife with a good wack and snapped the studs off. Caused no damage to the fender at all, I did this before I painted the truck so I wasn't worried about hurting the paint.
Old 10-21-2010, 04:01 PM   #7
srvivor71
srvivor71's Avatar
Re: Fender Emblems
I seriously thought about that but my paint is pretty good and although I may repaint in a while, I'd hate too pooch it up until then. Maybe I'll gently try that first and see what happens.
Chuck
Old 10-21-2010, 04:30 PM   #8
BIGBLU 72
BIGBLU 72's Avatar
Re: Fender Emblems
they make these little clips , i call them barrel clips, they have burs on them that push into the hole and the studs slide into the clip holding the emblem in place! i have used these on all the emblems on my jimmy with no problem
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 10-21-2010, 04:58 PM   #9
dougo
dougo's Avatar
Re: Fender Emblems
maybe look at the new ones, get an idea to where the "studs" are located on the used ones - drill them out, pop the old ones off and then pop the new one on with some of the recommendations from previous posts - just an idea.
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 10-21-2010, 05:23 PM   #10
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Fender Emblems
Chuck
I would put tape on the putty knife first to minimize scratches.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 10-22-2010, 08:33 AM   #11
srvivor71
srvivor71's Avatar
Re: Fender Emblems
Thanks guys, I got some really great suggestions here. Tomorrows the day; I'll post my results back here when I'm done.
Chuck
advice, fender emblems, installing
