Old 10-20-2010, 03:18 PM   #1
!969CSTLWB
Midshaft bearing Problem
Mine is bad. I got the bracket off and dropped the back shaft. I cant get it to seperate at the midshaft. It keeps wanting to slide out of the yoke. Is this because in has been pressed in somehow or am i I not tugging enough. The replacement bearing I got makes it look like both sides just slide in. Any input?
!969CSTLWB is offline   Reply With Quote
Old 10-20-2010, 05:37 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Midshaft bearing Problem
I did one long ago,so take this with a grain of salt.IIRC the yoke on the rear half slipped into the front half,then had a bolt thru the center holding it in.I think I had to remove the u-joint to remove the bolt so I could seperate the two shafts.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-20-2010, 05:45 PM   #3
w3lfd
I just did this job last weekend and that is correct. you have to pull the entire drive shaft assembly and remove the center u-joint. There is a bolt that holds the "ears" for the u-joint to the front driveshaft. That is the only way to remove the middle carrier bearing.
w3lfd is offline   Reply With Quote
Old 10-21-2010, 01:44 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
I do this on a weekly basis. Mark the shaft! So you can line up all of the piees of the driveshaft so it might have a chance of being ballanced. Pull ujoint, pull bolt, remove bolt on yoke remove carrier bearing. Please don't put shaft in a vice, they bend easily.
so why did the carrier bearing go bad? Age, ballance, mechanical failure?
good luck
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
