Old 10-21-2010, 02:31 PM   #1
robnolimit
robnolimit's Avatar
New fuel tanks
After working on the Streettrucks C-10, it was clear to us that standard C-10 tanks are not the hot ticket for Step-notched trucks. So, after some measurements and a few calls to Porterbuilt, we set out to build a custom tank that fits this type of build.
These tanks are 18 gallons, baffled and sectioned, and include new custom formed rear crossmembers. The new crossmembers are a direct bolt in for '67 to '87 stock rear rails, and will replace the stock rear crossmember. A new front mount square tube crossmember is also included. These tanks are "tucked-up" so that they don't hang down below the body, and include the filler cap.
Check out our website for more info
http://www.nolimit.net/prodinfo.asp?number=B5%2DTNK
robnolimit is offline   Reply With Quote
Old 10-22-2010, 03:51 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: New fuel tanks
Any pics bolted in ?
Malo83 is offline   Reply With Quote
Old 10-22-2010, 05:55 PM   #3
PRattenbury
Re: New fuel tanks
How much? Can you get one with a sump, set up for in tank electric pump?
PRattenbury is offline   Reply With Quote
Old 10-22-2010, 07:08 PM   #4
Michael Hill
Re: New fuel tanks
Rob, Im using the KP watts link on my rear end and was wondering if you know if there will be enough room between the watts set-up and the tank? Any help would be greatly appreciated. Nice tank hope we can get it for in-tank electric fuel pump?
Michael Hill is offline   Reply With Quote
Old 10-27-2010, 04:14 PM   #5
m6z
m6z's Avatar
Re: New fuel tanks
I would also like to see some installed picts.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
fuel tanks, gas tank, no limit, tank
