2007 GMC Yukon PLEASE HELP! Any info would be great
Ok So I was driving at like 5 mph In a parking lot, when the wheels lock up hard, screeches on the pavement and the trucks starts rolling again, I stop to see if maybe I ran over something, I see nothing then Put it in drive and the trans won't engage, So immediately think " damn my transmission just went out". But I drop the shifter all the way down To 1 and it drives, then I shift it up to 2 and its still driving.. At a dead stop the transmission will engage On 1 and on 2, It will not engage on 3 or on D. BUT I can shift the transmission manually From 1 to 2 to 3 to drive and it will drive with no issue.. I also have to down shift it manually because if I don't once I'm at like 20 mph it won't catch. It will just rev like I'm in neutral. It also makes a vibrating screeching sound some times.. This just happened 2 days ago..
Am I making any sense? Does any one know what might be wrong? Has any one experienced this before? again its a 2007 GMC Yukon with 79k on it The Trans never slipped it always shifted nice and smooth, any info would be great.. don't really know if the trans is a 60 or an 80.. How can I find out? Thank you all in advance Roger
......................_____ ![]() .........________//__{\_____ ![]() ,,,,,,,,,/__(O)__/____/_(O)_/ 1967 C-10, 383 1975 C-10, 454 SWB Buckets Low and Slow Baby! ![]() |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 2007 GMC Yukon PLEASE HELP! Any info would be great
Any ses light? Have you a ODB scanner?
Might be in "limp" mode, the PCM uses that to protect certain aspects of the computer/engine systems.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
No lights, nothing every things seem normal.. other than the fact that my auto is now a manual with 4 on the tree..lol
......................_____ ![]() .........________//__{\_____ ![]() ,,,,,,,,,/__(O)__/____/_(O)_/ 1967 C-10, 383 1975 C-10, 454 SWB Buckets Low and Slow Baby! ![]() Last edited by Morfias4Twenty; 10-26-2010 at 12:39 PM. |
Forward sprag is broken, Transmission needs to be tore down & rebuilt.
#5 | |
Thanks Clinebarger, Have u had similar situations? I have powertrain warrenty do you think that would cover it?
Ive rebuilt several units that have had this problem. Your warrenty should cover it.
yes it should but be sure to read your policy prior to taking it to a dealer. also depends on the mileage ( compared to warranty mileage) as to your deductible I believe.
http://www.gm.com/vehicles/warranty/....html?page=faq
Guys thanks a bunch, I talked to GMC and it will be coverd at no cost!!
this powertrain warranty is the BOMB!!! clyde65 that link was very helpful.. thank you
