Old 11-05-2010, 08:49 AM   #1
jasonroman
jasonroman's Avatar
bolt in c notch any good?
hey guys i was wondering if bolt in notch is any good. or is it better to weld in?
i dont have a welder, and have never welded. so thats why im asking if its worth bolting one in or better to have it welded in.
are there any pros vs cons ?
thanks
jasonroman is offline   Reply With Quote
Old 11-05-2010, 09:00 AM   #2
lakeroadster
Re: bolt in c notch any good?
Think of it this way, have you ever seen a truck frame (the frame itself) that was bolted together? Not the attachments to the frame, but the actual frame itself?
Therefore, from a pure strength and mechanical engineering viewpoint it is better to weld it in... but:
If you plan to use your truck, as a truck, hauling and towing, then you want a notch designed for towing and hauling and it should be welded to the frame.
If you plan to use your truck purely as a means of transportation, no hauling or towing, then a bolt in kit is sufficient.
Some of the simple c-notch kits are scary! Go with a reputable kit from a reputable company: Bell Tech, CPP and Porterbuilt all build a quality notch kit.
Here is a link to other posts that will no doubt provide you with hours of reading: http://67-72chevytrucks.com/vboard/s...=1957427&pp=25
Good luck and be sure to buy a good quality kit. This is one area that good engineering truly matters.
lakeroadster is offline   Reply With Quote
Old 11-05-2010, 09:10 AM   #3
jasonroman
jasonroman's Avatar
thanks for reply.
im looking at a kit from cpp. comes with a bolt in notch. i guess it can be welded in right?
or do i buy a specific for welding notch?
thanks for help and sorry for dumb questions.
Old 11-05-2010, 09:13 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Buy a good quality unit, bolt it in and enjoy. When you do the cut out for the notch be sure to drill holes where the cut lines intersect on the frame. This will help to prevent a sharp intersection that could promote stress cracking. Beyond that you should be fine.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-05-2010, 09:13 AM   #5
SCOTI
SCOTI's Avatar
Originally Posted by jasonroman View Post
thanks for reply.
Bolt-it in to get you going & then take it by a welding shop that can weld it properly.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-05-2010, 09:13 AM   #6
lakeroadster
If I were buying a kit I would bolt and weld, but that's me. I would suggest you call CPP and talk with them.
Old 11-05-2010, 09:14 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
thanks for reply.
Some kits are designed to be weld in only. There should be no difference other than the holes. If you really want to be sure, bolt it in and have it welded too. If strength is a concern, contact Jeff at CPP (CPPJeff) and ask about his super heavy duty unit.
Articles-
"Refining Sierra"
Old 11-05-2010, 09:19 AM   #8
jasonroman
jasonroman's Avatar
thats what i was thinking maybe as an option. didnt know if that could be done. i called a local shop for a price on installing spindles, flip kit, coils and a notch and dude told me 5oo. so 4 plus shipping for kit, then 500. seems alot to lower truck.
im not much of a mechanic, so i didnt think i would try this install myself.
my luck ill mess something up, or as in past, end up with extra bolts....
but thinking i may try it after i finish up my bodywork that i am attempting to do now.
not a body man either.
so we will see.
thanks for replies guys.
much appreciated.
Old 11-05-2010, 09:41 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Don't be afraid to tackle the lowering yourself. Find a buddy that has some experience and take it one end at a time. Its fairly straightforward and you can gain all the knowledge you need on this forum to be successful at the job.
Articles-
"Refining Sierra"
Old 11-05-2010, 09:42 AM   #10
MONTEZ
so we will see.
much appreciated.
Most shops would run around $1k for a static drop installed if they supply the parts. So that would be about right. Really though static drops are easy to install. Unbolt old parts, bolt in the new ones.... with a little modification here an there, but I'd say difficulty level wise, on a scale of 10, I'd give it a 3.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 11-05-2010, 09:46 AM   #11
jasonroman
jasonroman's Avatar
im strongly considering giving it a go.
i dont have many friends for help. or mechanic friends....
now a days, its me and my kids.
2 kids a wife and a ton of bills, you know the drill
anyway, ill keep looking for write ups on how to's.
i found one for the flip kit, but all pics were red x'd.
ill give it a try once holidays are over. xmas coming and my sons bday is on xmas......
so ill get there...just not tomorrow.
thanks again guys
Old 11-05-2010, 09:53 AM   #12
cdowns
cdowns's Avatar
weld in c notch looks better but as far as strength there really is no stress on the frame back there on a coil suspended truck unless you have a swaybar attached to the rear of the frame rail// so in most cases boltin is more than strong enough for the application
Old 11-05-2010, 10:07 AM   #13
lakeroadster
Unless you haul loads or pull a trailer. And long beds stress the notch area more than a shortbed.
Old 11-05-2010, 10:11 AM   #14
jasonroman
jasonroman's Avatar
dont have a boat to pull. and dont tow or load much, but its a truck i bought, to have truck abilities, so, i might just look to have it welded. maybe i can do the spindles, springs, and flip and just have notch welded in??
Old 11-05-2010, 10:19 AM   #15
SCOTI
SCOTI's Avatar
How much drop are you considering & what year truck?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-05-2010, 10:19 AM   #16
Shane
Shane's Avatar
Out of the thousands of bolt-in C-notches out there, I would be willing to bet not one person reading this post has ever encountered first-hand a C-notch failing due to being bolted in rather than welded.
Bolt-in is fine, even pulling a trailer or hauling loads.
The number and classification of fasteners used to attached the notch adequately equates to any welding process.
Shane is offline   Reply With Quote
Old 11-05-2010, 10:25 AM   #17
jasonroman
jasonroman's Avatar
truck is an 85 gmc
couple pics....truck, blue is 85
one shot of some sanding....grill, bumper, lights are off...little bodywork and then im priming the front, gonna pull off bed and do that seperate.
the gray one is my old 82...that i shoulda never sold....after a guy put fenders and a little body work for me.
plan on 4/6 or 5/7.....in that ballpark..
Old 11-05-2010, 10:47 AM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Based on what you have said I would approach it like this. Buy a drop spindle for the front and cut one coil off the stock spring. For a good deal on spindles take a look at the stickies in this forum.
For the rear you can buy a lowering shackle and raise the spring perch, or go with the flip kit. If you can save the money by doing it yourself, maybe consider have a "competent" shop build a small rear notch.
Please DO NOT consider AIM/Chassis Tech to cut costs
Articles-
"Refining Sierra"
Old 11-05-2010, 11:44 AM   #19
jasonroman
jasonroman's Avatar
coils, drop spindles, flip kit and c-notch kit...<<<this is what jeff at cpp told me he could get me for my desired 4/6 drop.
im pretty sure thats with a 2.5 spindle....now after reading here and there i think i may want 3 inch spindles. mainly because, i, like many will prob want it lower.
but figure 3 in spindles. cut one coil off front. >>>i was thinking about cutting coil off front spring....maybe i dont need cpp coils??? or maybe better off just getting them with kit??
flip kit for rear. ive read you need notch for this drop, and then ive read you dont need notch for this drop, but i will want a notch. the 82 had one and it drove great.
maybe im better off, splitting up the kit...
getting 3 in spindle.
flip kit.
no coils or notch....
use my springs for now, and buy a weld in notch instead of bolt in notch.
im planning on pulling bed at some point.
so if it aint too much of a pain to put on and off, i can, fingers crossed, install spindles and flip sucessfully, and then have notch welded in.?
n2trux....you saying maybe i can save on notch buy having a shop that can, make me one for less than i would pay for a notch?
Old 11-05-2010, 11:45 AM   #20
SCOTI
SCOTI's Avatar
4/6 drops likely won't need a c-notch; 5/7 drops will.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-05-2010, 01:13 PM   #21
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
AVS sells this one for 73-87 but it is most likely bigger than what you want/need for a static drop. Just another option.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 10-14-2018, 05:04 PM   #22
catch2otwo
food for thought.
http://www.67-72chevytrucks.com/vboa...d.php?t=457037
edit: oops sorry for the resurection
catch2otwo is offline   Reply With Quote
