Old 11-10-2010, 02:18 AM   #1
longbedted12
Tail Light Issues
Hey everyone I need some help.
I have a 70 c-10 that had major wiring issues when I bought it. I replaced the whole dash harness and the turn signal mechanism and everything worked fine.
Now however, my tail lights don’t work. They light up when my blinker is on and when my head lights are on, thats the only time. only my left back up light works as well.
I’m stumped. Any info would help.
Thanks, longbedted12
longbedted12 is offline   Reply With Quote
Old 11-10-2010, 10:01 AM   #2
Sammy
Re: Tail Light Issues
Check all the connections by pulling each apart and reconnecting them cleaning starting with the dash harness, neutral safety, flasher unit, harness to headlights and to tail lights. 90% of the time always it's a bad ground or a bad connection from a splice.
"Now however, my tail lights don’t work. They light up when my blinker is on and when my head lights are on, thats the only time. only my left back up light works as well."
Fleetside tail light housings bulb connections are a common corrosion area. The cross over tail harness gets alot of abuse from previous trailer connections and the elements. Good Luck and post the final fix.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
electrical, harness, tail lights, turn signal
