Old 11-16-2010, 03:14 AM   #1
big_r101
big_r101's Avatar
73-87 1-ton capacities
didnt reall know what else to call the thread but whatever, i was wondering of the 73-87 1 ton which year would be the heaviest duty? (like payload capacities, axles, etc.)
1998 Ford Ranger FX4, 3.0 V6, 5 speed manual
1999 Ford Explorer, 4.0 V6, 5 speed auto O.D.
2005 Chevy Colorado, 3.5l inline 5, 4 speed auto
2001 Gmc sonoma 4.3l V6, 4 speed auto
soon to have 1981-88 k30
big_r101 is offline   Reply With Quote
Old 11-16-2010, 05:04 AM   #2
Number21
Number21's Avatar
Re: 73-87 1-ton capacities
They may have gotten a bit heavier towards the end of their run, but I would think most 73-87 1 tons are about the same. They can vary within the model year from about 8,800GVW to over 10,0000GVW. In most 1 tons I believe you will find the 14 bolt full floater rear end.
Interestingly my '73 3/4 ton is only rated 800lbs less than my '79 1 ton. (8200 vs 9000 GVW)
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 11-16-2010, 06:52 AM   #3
GM72K10
Next!
GM72K10's Avatar
Some of the "1 ton" Cab and Chassis actually are 11,000 gvw.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 11-16-2010, 08:08 AM   #4
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Like he said it will vary depending on 4wd/2wd, cab/bed configuration, SRW/DRW, etc. Also 14 bolt FF came in later model years, earlier ones had the Dana 70 rear.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 11-16-2010, 11:01 AM   #5
babyJay
Arrived on a Pale Horse
babyJay's Avatar
As mentioned the above factors all affect the capacity of the truck. If you're looking to Max capacity you'll have to roll with a dually.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-16-2010, 07:51 PM   #6
iroc12valve
I have a 1991 V3500 same as an 86 k3500 (same idea as the burbans/k5s)
dana 60 front 14 bolt rear factory overload springs.
its set for 9900#
EDIT its an SRW truck and came with 16's not 16.5's
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
Old 11-16-2010, 08:44 PM   #7
GCncsuHD
GCncsuHD's Avatar
its set for 9900#
I'll have to check the GVWR on my 78 K30 Dually tonight when I head out to the gym, it's pulling DD duties right now
ΜΟΛΩΝ ΛΑΒΕ
Old 11-16-2010, 09:43 PM   #8
big_r101
big_r101's Avatar
well i was most likely goin with a crew cab dually 4x4, preferably an 80s one because i like the style of the front end and interiors, and at some point i was goin to upgrade the rear to a dana 80 with 3 inch wide leafs, probly do that after i get the money to do a diesel swap
Old 11-27-2010, 04:51 PM   #9
GCncsuHD
GCncsuHD's Avatar
Checked mine, it's 10,000 GVWR
ΜΟΛΩΝ ΛΑΒΕ
Old 11-28-2010, 01:58 AM   #10
K30_dump
Hello,
My '84 K30 cab-and-chassis has a GVW of 11,000 lbs. For what its worth, the cab-and-chassis frames were slightly heavier than the K30 pickup frames (either SRW or DRW pickups). Channel height was the same, but rails were approximately .030" thicker. They also have a heavy crossmember for the rear cab mounting, as opposed to the individual mounting brackets found on the pickup frames. Just something to think on...
Hope this helps,
Joe
K30_dump is offline   Reply With Quote
Old 11-28-2010, 07:15 PM   #11
gregg72340
gregg72340's Avatar
A friend of mine just bought a 79 GMC High Sierra 35 1 ton ex firetruck and I dont know much about it other than it was GVWR at 27,500!!! We have no idea why just thought it was very odd
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!!
gregg72340 is offline   Reply With Quote
Old 11-28-2010, 07:56 PM   #12
GCncsuHD
GCncsuHD's Avatar
Something sounds off there. Sure it didn't possibly have a door plate off a C60 or something? The GCWR should not even be that high. Maybe someone messed up the door at some point and replaced it with one from a junkyard medium duty truck.
If that was true, he would have to have his CDL's to even drive the truck.
ΜΟΛΩΝ ΛΑΒΕ
Old 11-28-2010, 08:40 PM   #13
gregg72340
gregg72340's Avatar
Oh yeah definitly think it is weird, so I dont think he has figured that outyet, just seems really odd thats what was listed on the title, its was nothin special just a one ton fire company air truck
Old 11-28-2010, 08:45 PM   #14
78customdeluxe
My 88 2wd crew cab dually come from the factory at 10,000 pound, but I think I read that the crew cab dually 4x4 was 11,000 from the factory. Then I have a 79 k-30 single wheel that is 9200lb, which is ironicly the same as my old truck I had, an 82 3/4 4x4 with the semi-floater 14 bolt...
88 Crewcab Dually 5.9 Cummins, 5306 Eaton 6-speed, converted 4x4 w/52's up front, 90 front clip(parting out)
1986 ElCamino (needs motor)
1970 C30(future service truck for my ag-equipment repair business)
1970 CST10(parting out and partial donor for the '70 C30)
2000 GMC 1500 ext cab sb, z71, 5.3 loaded auto
78customdeluxe is offline   Reply With Quote
Old 11-28-2010, 08:52 PM   #15
70BLAZERX2
My rollback is made on a 1977 GMC Motor Home Chassis...GVW is 14,500
19.5 wheels and 4 wheel disc brakes..454 th400 and gets the job done..truck is 7,000lb's empty..Have been on the scales at 16,800 loaded..
frame is doubled from factory over rear axle.
70BLAZERX2 is offline   Reply With Quote
Old 12-10-2010, 01:00 AM   #16
big_r101
big_r101's Avatar
very nice rollback you got there, like the color and stacks
Old 12-10-2010, 09:50 AM   #17
78 Chevyrado
This should answer all your questions.
GM Heritage Center
78 Chevyrado is offline   Reply With Quote
Old 12-10-2010, 06:15 PM   #18
GM72K10
Next!
GM72K10's Avatar
Is that the one off CL for $900.00?
86 K30 CUCV M1028A1
Old 12-11-2010, 11:35 AM   #19
MofoG23
MofoG23's Avatar
GM Heritage Center
Awesome link!!!
1976 K20 350/205/465 - "Big Red"
2010 VW GTI
2013 VW Touareg
MofoG23 is offline   Reply With Quote
Old 12-11-2010, 03:44 PM   #20
big_r101
big_r101's Avatar
yea i checked that place the other night and found ALOT of usefull info on there
