Old 03-24-2002, 09:09 PM   #1
jason7627
Question tcs switch?
Gettin my '72 ready for the 454 and found a set of wires for what my wiring diagram calls a tcs switch.It shows a tcs switch and tcs solenoid, but they are no longer there, just the wiring. 3 questions. 1) What does it do? 2) Can I get rid of it. 3) If I can't get rid of it anyone know where I can get parts for it?
1972 Custom lwb 402/th400/3.73 soon to be 454
72 lwb 468/th400/3.73 2/4 drop primer
jason7627 is offline   Reply With Quote
Old 03-25-2002, 12:19 AM   #2
71Chev
71Chev's Avatar
Post
I think it is transmission controled spark or something close to it.
Not exactly sure what it does.
Mine isn't hooked up and it runs fine, so I don't think ya need it.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 03-25-2002, 12:20 AM   #3
72gmc1/2ton
Post
TTT
72gmc1/2ton is offline   Reply With Quote
Old 03-25-2002, 07:58 AM   #4
Blazer1970
Blazer1970's Avatar
Post
Search and you will find.
Blazer1970 is offline   Reply With Quote
Old 03-25-2002, 08:27 AM   #5
JimKshortstep4x4
Smile
The TCS switch controls the vacuum going to your vacuum advance on your distributor. It allows vacuum to the vacuum advance under two conditions: 1) The engine temperature at normal, 2) The transmission is in high gear. It basically keeps the timing retarded as far as the vacuum advance goes when the engine is cold or when the transmission is in the lower gears. The prevailing theory at the time for emissions was to retard timing to cause the manifolds/exhaust to get hotter, therefore burning the emissions.
The effects on performance and gas mileage were pretty detrimental. I have always suspected that the net effect of the TCS setup was to increase emissions overall, but I have never seen any studies.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-25-2002, 11:14 AM   #6
Fast68Chevy
Fast68Chevy's Avatar
Post
easy fix is to just run the advance hose straight formt he distributor advance diapragm to the carb base, there, done...
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
r68c30@hotmail.com
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 03-25-2002, 09:51 PM   #7
jason7627
Post
Thanks, looks like its out of here.
