03-25-2002, 08:06 PM | #1 |
BIG BLOCK MOUNTS
Can someone confirm this...... The 1972 402 BB C10 came with either one of two different motor mount brackets. One style was a carry forward from the previous years (the same you would likely find in say a 69,70 or 71) it looks kinda like the small block brackets. The other style which was more commonly found was the 3 piece per/side more of a straight tower and a cup style bracket that bolts to the block with the rubber mount in between.
My question is has anyone seen the earlier style brackets on a 72, or did they just use the one style in 1972? Thanks
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK. My build thread: http://67-72chevytrucks.com/vboard/s...=1#post7120181 |
03-25-2002, 08:21 PM | #2 |
Born Psycho
i've only seen the 72 style on 72s but it is very possible some early 72s could have got carry overs from 71. i've owned a couple 72 big block trucks and they had 72 style mounts.
------------------ jerry 72 cheyenne super K20 72 cheyenne K20 72 custom K20 - FOR SALE 79 K-5 90 SS454 PICKUP BRENTWOOD,CALIFORNIA
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
03-25-2002, 10:15 PM | #3 |
I put in a 454 from a 1982 suburban. The brackets i used where from that same suburban. They bolted on with not much work.
Hope this helps. |
