Old 01-18-2011, 04:05 PM   #1
Mrtn15
Mrtn15's Avatar
Unhappy Questions about 86 truck not starting.
Okay, usually on cold mornings my truck Just fires up first turn of the key, no pumping on the gas, nothing. This morning, My truck did not start.. I pumped on the gas, and it tried once, but nothing. It turns over, but never tries to run.
I pulled my fuel line off of my carb, and pumped my gas; And no gas squirted out.
I put gas into my carb, and my truck starts and dies VERY quickly.
What does this sound like to you guys?
305 or 350 Motor. Th350 Tranny. Swb\2WD.
1986 Single cab 2WD Chevy 350/350
1977 Single cab Dually C30 BB454!
Mrtn15 is offline   Reply With Quote
Old 01-18-2011, 04:23 PM   #2
Mrtn15
Mrtn15's Avatar
Re: Questions about 86 truck not starting.
Old 01-18-2011, 04:35 PM   #3
terryj
Bad fuel pump !
terryj is offline   Reply With Quote
Old 01-18-2011, 04:37 PM   #4
Mrtn15
Mrtn15's Avatar
Is that the only thing it could be ?
What would you suggest on buying a new one? Should I get an Edelbrock one, or just a stock one. Edelbrock isn't any better is it; just chrome ?
Old 01-18-2011, 05:11 PM   #5
rhdowns
Yeah sounds like a fuel pump issue. Probably the diaphram in the pump went out. It should be a manual fuel pump and yes the edelbrock is just shiny.
You will also need a fuel pump rod - local parts store should be able to sell you one. It is a little tricky to get the rod up in there without a second person.
86 K10 Shortbed
Skip White 383 \ 700R4 3.73 rear
rhdowns is offline   Reply With Quote
Old 01-18-2011, 05:14 PM   #6
Mrtn15
Mrtn15's Avatar
So I shouldn't just buy a whole fuel pump?!
Old 01-18-2011, 05:19 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Is it carb or tbi?
not pumping before a start sounds FI
how cold ?
frozen gas line?
how much gas in the tank?
seen cars parked on a slope not start,because of a frozen line!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-18-2011, 05:22 PM   #8
Mrtn15
Mrtn15's Avatar
It's not freezing here, It's a carb! And it's got about 4 or 5 gallons dual tank truck my gas gauge stopped recently if that matters
Old 01-18-2011, 05:29 PM   #9
rhdowns
All carbs until 87 I think right?
First guess was choke wasn't working right but when he said no fuel was coming out that definitely sounds like a fuel pump and is also a cheap fix.
You can get a fuel pump from skipwhite that is chrome for pretty cheap. I have one on my new motor and it works good.
86 K10 Shortbed
Old 01-18-2011, 05:45 PM   #10
allengator
allengator's Avatar
Pumping the gas wont make fuel squirt out with the fuel line off....
Cranking the engine should!
If you crank the engine and fuel and spurts, your pump is good...
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 01-18-2011, 05:49 PM   #11
rhdowns
Great point Allengator.
86 K10 Shortbed
Old 01-18-2011, 05:51 PM   #12
Mrtn15
Mrtn15's Avatar
Okay, my engine won't run, and when I turn my key and it's turning over, no fuel! And thanks rhdowns! I will look into those fuel pumps. I hope this is the problem my fuel pump doesn't feel like its pumping!
Old 01-18-2011, 08:03 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
Question Re: Questions about 86 truck not starting.
I went by you saying" just turn the key , no humping required"took that to be fi
Andpumping the gas would be carb if it squirted"inside"
And yes fi wasn't factory yet ,but Vins can be changed, my 85 burb lost 3 birthdays this year lol
John
Old 01-18-2011, 08:40 PM   #14
Mrtn15
Mrtn15's Avatar
Lol that's funny, trucks can change age, why can't we haha! But yeah I hope it's my fuel pump! I'm ordering one tomorrow
Old 01-18-2011, 09:39 PM   #15
terryj
Loosen the fuel line at the fuel pump and see if you are getting fuel to the pump if you are check the output of the pump, crank the engine and see if fuel is being pumped to the carb. If you have a fuel filter before the pump it could be a clogged fuel filter.
Old 01-18-2011, 10:26 PM   #16
Mrtn15
Mrtn15's Avatar
Oh wow that's good to know! I will check that later! I honestly don't know where the fuel filter is! I don't have an in line one
Old 01-19-2011, 02:05 AM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
fuel filter is at the inlet @the carb i think it's got an inch nut after the line ends
put the line in something you don't want gas all over and to be carefull of a backfire.....
John
Old 01-19-2011, 02:25 AM   #18
Mrtn15
Mrtn15's Avatar
Could you post a pic of what your talking about
Old 01-19-2011, 03:00 AM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
can't find one but follow your fuel line to the carb @ the point of entry the big nut holds the filter in place
loosen the line then the big nut(use wrenches to hold em when turning)
John
Old 01-19-2011, 10:23 AM   #20
rhdowns
We actually checked my fuel pump by taking it off and then plugging the inlet and outlet hole and pressing down on it on a desk and then letting fingers off the hole - if it isn't busted it makes a little air sound from the pressure getting out.
That works if you don't have someone around to turn the engine over while you are up at the pump.
86 K10 Shortbed
Old 01-19-2011, 05:45 PM   #21
TDS-MN
I'm betting fuel pump as well. Was down that same road with my '85 last spring, actually.
Symptoms I experienced prior to pump failure were a sputtering and very rough idle. It finally stalled just as I pulled into my parking space, not to restart until the pump was replaced. i think that was the 3rd pump the truck has ever had since new.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 01-19-2011, 05:47 PM   #22
Mrtn15
Mrtn15's Avatar
Well mine would idle fine at first, and only sputter when going down the road at 70 and it started sputtering at lower and lower speeds, and then at idle. And the other day I went to the grocery store, and it tried to start, and died and hasn't started since!
Old 01-19-2011, 06:40 PM   #23
Mrtn15
Mrtn15's Avatar
Originally Posted by rhdowns View Post
All carbs until 87 I think.
Okay this is the sight I went too!!
http://www.skipwhiteperformance.com/...aspx?Product=H
Which one did I get?
Old 01-19-2011, 07:12 PM   #24
rhdowns
http://www.skipwhiteperformance.com/...x?Item=PC-2751
This is the one you need. You also should get a new fuel rod like I said. I think I paid like 10 bucks for mine at advanced auto.
86 K10 Shortbed
Old 01-19-2011, 07:24 PM   #25
Mrtn15
Mrtn15's Avatar
Is tht one universal for 305's and 350's
adivce, chevy c10, dead, fuel pump, gas
