Old 01-19-2011, 05:40 PM   #1
dubb702
3/4 vs 1/2 ton frames
i have a 3/4 ton frame chevy want to know can i use 1/2 ton gmc
i dont know the difference the radiator support cross-member is not the same
as far as i can tell
dubb702 is offline   Reply With Quote
Old 01-19-2011, 09:24 PM   #2
Deabt54
Deabt54's Avatar
Re: 3/4 vs 1/2 ton frames
Hi Dubb welcome to the site, as far as I know the 3/4 ton frame should be about 12.23 inches longer than the 1/2 ton frame which means your 1/2 ton bed will be short. I'm not sure about the radiator support, you might be able to make that work. Here's some links that might help http://chevy.oldcarmanualproject.com...resto/5055.htm http://www.stovebolt.com/ubbthreads/
Post some pics, Dean....
Deabt54 is offline   Reply With Quote
Old 01-20-2011, 06:18 PM   #3
sweet70beast
sweet70beast's Avatar
You didn't say what years you were looking for so here is the Chevy support for 47-54.
[IMG][/IMG]
GMC support 47-54
[IMG][/IMG]
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 01-23-2011, 10:31 AM   #4
dubb702
thanks for all replies the years are 47-54 mine is a 53 though i been doing alot of comparing since i have both frames now . But i should of compared the GMC 1/2 ton vs. Chevy 1/2 ton .what im going to do is take everything off the 3/4 chevy and install it on my gmc 1/2 ton frame. i found out that gmc 1/2 ton frame is longer and the radiator support are diff .
thanks for alll help
Old 01-23-2011, 12:10 PM   #5
MrTucker
MrTucker's Avatar
From all of the research I've done, the 1/2 ton vs. 3/4 ton frame differences are very minor. One website says they're the same, the next says a 3/4 is a bit thicker, but I haven't been able to confirm this. I've also read that the lengths are different between GMC and Chevy frames - again, I cant confirm this.
And just because it is a long bed does NOT mean it's a 3/4 ton! I have a 1/2 ton long bed.
1953 GMC 1/2 ton long bed
Original 228 I6 with a Hydramatic Auto Tranny
Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649
MrTucker is offline   Reply With Quote
Old 01-23-2011, 02:09 PM   #6
sweet70beast
The GMC pictured above is a 51 1/2 ton long bed too. The Chevy pic is from my 47 Panel.
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
