Old 01-22-2011, 05:07 AM   #1
slammed89burban
89 burban 5 lug to 6ug conversion with oem parts is it possible?
ive been searching for a while but dont seem to find what im looking for, i am trying to swap my 5 lug 2wd suburban to a 6 lug and i have a 89 suburban 4x4 as a parts truck if i can do this or use any of these parts in the process.
please if anyone can even point me the the right direction someone has had to have tried this.
thanks,
Jeff
slammed89burban is offline   Reply With Quote
Old 01-22-2011, 10:32 AM   #2
1badgmc
1badgmc's Avatar
Re: 89 burban 5 lug to 6ug conversion with oem parts is it possible?
I was working on a reply for you, until I realized you're trying to convert an '89 Suburban. Since the '89 Suburban is still a square body, you'll probably be able to better find someone to help if you posted this in the '73-'91 SUV forum or even the '73-'87 truck forum.
Old 01-22-2011, 10:52 AM   #3
russgt
russgt's Avatar
I have done a similar swap on a 70 c10. I dont know if these parts would work on your 89, but a swap rotor for the front and maybe you can take the axle shafts out ( or complete axle) of the 4x4 and put them in the 2 wheels axle?
http://67-72chevytrucks.com/vboard/s...d.php?t=340264
You would have to watch your wheel studs or you may end up with different lug nuts on the front and back
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 01-22-2011, 01:20 PM   #4
slammed89burban
thanks for the reply's and thanks to whoever moved it
Old 01-23-2011, 11:28 AM   #5
mopar346
What is the wheel mounting surface to surface width on both assemblies? Spring perch width on both? Can you just swap complete assemblies by moving the perches and maybe using an adapt-a-joint. The other option maybe to have the axles cut down and re-splined, if the wheel bearing is the same. You could order custom axles from someone like Dr.Diff. One thing to keep in mind is no matter what you do, you have to figure on brakes that match.
mopar346 is offline   Reply With Quote
Old 01-25-2011, 12:46 AM   #6
kevinr1970
I just went 6-lug to 5-lug:
http://67-72chevytrucks.com/vboard/s...d.php?t=433726
There is a post in there about the spline count being different for 1989-91 so your parts truck might have what you need.
I believe that CPP or ECE (or PDQ?!?) makes a 6-lug rotor for 67-72 trucks that have converted to the "newer" '73-87 style front suspension but want to maintain the 6-lug for originality.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-25-2011, 12:54 AM   #7
63chevyll
gets board easy.......
63chevyll's Avatar
hmmm, id like to know too about those rotors
63chevyll is offline   Reply With Quote
Old 01-25-2011, 05:41 PM   #8
russgt
russgt's Avatar
http://www.classicperform.com/Store/...ruck/CP4R5.htm
70 stepside
76 blazer
86 Silverado
71 Nova SS
