Old 01-25-2011, 02:43 AM   #1
1964c-10
1964c-10's Avatar
My 1964 C10
Alright guys,
Here are some pics of what my truck looked like before it was drug over to dads shop
1964c-10 is offline   Reply With Quote
Old 01-25-2011, 02:48 AM   #2
1964c-10
1964c-10's Avatar
Re: My 1964 C10
truck in the shop, and a few pics of the rust problems
Old 01-25-2011, 02:52 AM   #3
1964c-10
1964c-10's Avatar
Re: My 1964 C10
front end removed, and the bed is torn out, a few pics of the 350 all painted up
Old 01-25-2011, 02:55 AM   #4
1964c-10
1964c-10's Avatar
Re: My 1964 C10
here are a few pics of us removing the cab from the frame, 2 people were able to lift the bed off after it was loose.
Old 01-25-2011, 03:23 AM   #5
Captainfab
60-66 Nut
Re: My 1964 C10
You're not messin around, are you. What's the plans for your truck?
Old 01-25-2011, 04:10 AM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 1964 C10
Jason, great job so far! After talking with you the other night, I remembered I know where there a couple of these old trucks sitting. They are south of Baxter. I don't know if they will sell parts off of them, but I'll gladly show you were they are at. One was a lwb in pretty decent shape.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-25-2011, 10:44 AM   #7
1964c-10
1964c-10's Avatar
Re: My 1964 C10
I guess my plans are to set it up with all factory look with a little extra under the hood
Ryan that would be great, i've kinda been waiting til the snow melts some more before i go parts digging
Old 02-14-2011, 09:40 PM   #8
jce4isu
jce4isu's Avatar
Re: My 1964 C10
any updates
jce4isu is offline   Reply With Quote
Old 02-15-2011, 12:41 AM   #9
1964c-10
1964c-10's Avatar
Re: My 1964 C10
lately i've been working on the bed, drivers side and the front peice. i had to trim off the bottom 6" all around the inside of the box because of rust. i had a local guy bend the sheet metal. i took the hood and right bed side in to my local body shop to get dents pulled out. i got the intake swapped and my new holly put on the 350. yesterday i cut out one of my cab corners and cut off the lower cowls.
A few more pictures
Old 03-21-2011, 01:23 AM   #10
1964c-10
1964c-10's Avatar
Re: My 1964 C10
alright time for some updates,
first pic is of the back of the cab sand blasted before we tipped it over
second pic is some of the rot on the underside of the cab
third pic is of all the rot cut out of the drivers side floor
forth pic is of the inner and outer rocker panels installed
fifth pic rockers on the drivers side
Old 03-21-2011, 01:29 AM   #11
1964c-10
1964c-10's Avatar
Re: My 1964 C10
1 passengers side cab supports on
2 entire floor patched and rebuilt
3 A-arms in Chassis Saver
4 patch put in over rear coil spring mount
5 bottom of cab/ firewall in Chassis Saver
Old 03-21-2011, 01:35 AM   #12
1964c-10
1964c-10's Avatar
Re: My 1964 C10
1 frame in Chassis Saver
2 rear wheel wells, inner fenders, front cross member in Chassis Saver
3 new steering stop installed
4 Disc spindals, air bags, new bushings, and ball joints installed
5 another pic of the frame
Old 03-21-2011, 01:38 AM   #13
1964c-10
1964c-10's Avatar
Re: My 1964 C10
sorry
Old 03-21-2011, 01:43 AM   #14
1964c-10
1964c-10's Avatar
Re: My 1964 C10
1 as she sits right now, front disc installed and all four air bags
2 here is a before/ after pic of us using acid to eat rust and paint off of the A-arms
Old 03-31-2011, 06:18 PM   #15
1964c-10
1964c-10's Avatar
Re: My 1964 C10
1 sanding some new metal for primer
2 parts hanging in my make shift paint booth
3 me spraying some primer for the first time
4 parts primed
Old 03-31-2011, 09:20 PM   #16
biohazardbill
Re: My 1964 C10
Are you liking the Chassis Saver?
biohazardbill is offline   Reply With Quote
Old 03-31-2011, 09:49 PM   #17
1964c-10
1964c-10's Avatar
Re: My 1964 C10
I am pretty happy with it, i brushed it all on and some places on the bottom of the cab kinda bubbled- it looks like i painted over sand blasting sand but i know i had it clean. after 1 coat on the chassis i went around and touched up places were the paint was light and you can clearly see the difference between 1 and 2 coats. the areas with 2 coats are a lot more shiney than where there is only 1 coat so i need to put a second coat over the whole thing. it seems to be pretty tough stuff (I still have some stuck on my skin after 2.5 weeks) i dont know how it would compare to POR 15 because i ve never used it before.
i let some set up in a pop bottle i was painting out of, and after cutting the bottle off the paint is like a plastic. (hope that makes sense).
my advice for brushing it is to put on as light of a first coat as you can to prevent runs, and wear gloves and long sleeves to keep the stuff off your skin.
Old 04-01-2011, 07:57 AM   #18
biohazardbill
Re: My 1964 C10
Thanks for the onfo, my local paint place is trying to talk me into it. How shiny is it, think it would clash with flat black on the other areas of a truck?
Old 04-01-2011, 09:18 AM   #19
1964c-10
1964c-10's Avatar
Re: My 1964 C10
you can kinda see in my pictures that it comes out in a gloss or high gloss finish. but remember you can top coat it with whatever you want from my understanding.
Old 04-04-2011, 02:12 AM   #20
1964c-10
1964c-10's Avatar
Re: My 1964 C10
Shot some paint for the first time this weekend! it came out pretty well considering my skill level, no runs! i decided to go the base/clear route, because it is going to offer the most protection against weather, rocks, scratches. i used Dupont basecoat/ Nason clearcoat 3 coats color 2 coats clear, i still need to sand and buff the clear.
Old 04-29-2011, 01:58 PM   #21
1964c-10
1964c-10's Avatar
Re: My 1964 C10
sorry for not posting any updates lately for anyone who is following this build. i have been working on finishing up the bodywork on the cab, and will have the bondo finished today and it should be in primer tonight and paint tomorrow. i will get some pics of the process and post them up on monday probably.
2003 Serria K1500
1998 Camaro
1964 C10 long fleetside bed, small back window, 3 on the tree
1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor
Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website.
Old 05-01-2011, 06:19 PM   #22
1964c-10
1964c-10's Avatar
Re: My 1964 C10
this weekend i got the cab painted inside and out. went with the original two tone paint scheme - fawn and ivory. it came out pretty well except for a few runs in the clear on the roof but nothing i can't fix.
2003 Serria K1500
1998 Camaro
Old 05-12-2011, 02:30 AM   #23
1964c-10
1964c-10's Avatar
Re: My 1964 C10
I dont have any new pics, but since my last post i've gotten the cab mounted, pedal assm. installed, steering column in, tranny in, gauge cluster in, and the motor will be going in tomorrow and probably ready to run friday. i ordered my Hooker 2452's last night so whenever they come i'll start the motor.
2003 Serria K1500
1998 Camaro
Old 05-12-2011, 09:38 AM   #24
chevyrestoguy
chevyrestoguy's Avatar
Re: My 1964 C10
Man, that thing is looking good! I have always liked the Fawn/Ivory color combo, too.
Post pictures when you can. Love to see the progress.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-12-2011, 10:58 AM   #25
1964c-10
1964c-10's Avatar
Re: My 1964 C10
thanks, I'll try to get some more pics up tonight
2003 Serria K1500
1998 Camaro
