Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 02-09-2011, 01:00 AM   #1
Captainfab
60-66 Nut
6 Lug Rear Disc with E-Brake Brackets
This set of brackets will allow you to have rear disc brakes on your 6 x 5.5 bolt pattern ’64-’87 GM truck 10 and 12 bolt rear differentials. This rear disc conversion is completely bolt on with one exception. The drum/wheel register will need machined down to approximately 3.06”. I do recommend upgrading to ½” wheel studs at this time, but it isn’t absolutely necessary for the installation. The rotors used with these brackets as well as the calipers are easily found at your local auto parts supplier. The basic application for the rotors is a 2000 Silverado or Suburban. The application for the calipers is the ’93-’97 F-body rear calipers. A complete parts list with part numbers is included with the brackets.
Since these rotors are nearly 13” in diameter, you will need to run 16” or larger diameter wheels. With the 16” wheels I would suggest verifying that your wheels are compatible with this size of rotor prior to purchasing this disc brake conversion.
The cost on this set of brackets with installation hardware is regularly $120.00. However, thru March 31, 2011 the introductory price is $100.00. Satin black powder coating is an additional $12.50. Shipping within the USA is a flat $11.65. If you are outside of the USA, contact me for a shipping cost. For payments I accept PayPal and money orders. Credit card payments can be made thru PayPal. To place an order, you can send me a PM here on the forum or you can email me at captainfab454 at hotmail dot com.
I would like to thank a former member here, grendel for contacting me about making these brackets, and for supplying a rotor suggestion as well as installed photos.
In a couple of days I will post a pic of the complete package you are purchasing.
Captainfab is offline
Old 02-09-2011, 01:33 AM   #2
Captainfab
60-66 Nut
Re: 6 Lug Rear Disc with E-Brake Brackets
Here are some pics from grendel's installation
Old 02-12-2011, 10:36 AM   #3
Greywolf200
That's a cool looking setup. I'm going to look at it a lot closer if I go to bigger wheels.
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline
Old 02-12-2011, 05:54 PM   #4
Captainfab
60-66 Nut
Thanks for the compliment.
Yes, that is the one thing about the rotors bigger than about 12", is you can't run a 15" wheel.
Old 02-12-2011, 06:00 PM   #5
hd74
i have a gmc with a dana 44 rear end do you think this would work??? thanks
hd74 is offline
Old 02-12-2011, 06:46 PM   #6
Greywolf200
I'll x-post this question cause I don't know which is the correct place to put it. From looking at the specs, it looks like your D52 kit will work with a '96 K1500 rotor if you make your spacer 5/8" thinner.
Jack Byrd
Old 02-13-2011, 01:07 AM   #7
Captainfab
60-66 Nut
Sorry, no these brackets will not work on a Dana 44. The backing plate flange has a different bolt pattern and I'm not sure if the brake offset is the same as a 12 bolt.
Old 02-13-2011, 01:19 AM   #8
Captainfab
60-66 Nut
You are correct in that a 5/8" spacer will line up the caliper with the '96 K1500 rotor, but that rotor will not accomodate a D52 caliper and pad. I already tried that a while ago. I have plans on working on a conversion utilizing the '88-'98 K1500 rotor, but with the D369 calipers. Those are the ones that are OEM on the '88-'98 K1500's. These will work with 15" wheels.
Old 02-19-2011, 03:24 PM   #9
localmotion74
The cost on this set of brackets with installation hardware is regularly $120.00. However, thru March 31, 2011 the introductory price is $100.00. Satin black powder coating is an additional $12.50. Shipping within the USA is a flat $10.00. If you are outside of the USA, contact me for a shipping cost. For payments I accept PayPal and money orders. Credit card payments can be made thru PayPal. To place an order, you can send me a PM here on the forum or you can email me at captainfab454 at hotmail dot com.
localmotion74 is offline
Old 02-20-2011, 01:21 AM   #10
Captainfab
60-66 Nut
Localmotion74, was there something you had to say??????
Old 03-24-2011, 10:20 PM   #11
Captainfab
60-66 Nut
Ttt
Old 03-25-2011, 08:51 AM   #12
Greywolf200
Ttt
New here? What does Ttt mean? Did you ever get pics of the ebrake kit? I've acquired a pair of Eldorado rear calipers.
Thanks,
Jack Byrd
Old 03-25-2011, 08:52 AM   #13
Greywolf200
Thanks,
Sorry, wrong thread.
Jack Byrd
Old 04-03-2011, 04:10 PM   #14
bryce763
hi what do you me you need to machine down?what area? thanks jason how about shipping to 55330 mn thanks jason
bryce763 is offline
Old 04-04-2011, 12:38 AM   #15
Captainfab
60-66 Nut
The drum/wheel register needs to be machined down from 3.50" to aprox 3.06" to be able to fit the rotor onto the axle flange. This is the area indicated by the red arrow in the pic below.
Minnesota is within the USA so the flat rate shipping of $10.00 applies.
Old 04-07-2011, 09:44 AM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
.....The drum/wheel register will need machined down to approximately 3.06”. ....
If you are considering this conversion, you might want to look at replacing the old axles. The new axles can be ordered with the correct size drum register.
If you factor in the cost of machining 40+ year old axles, it might be worth applying that expense toward brand new ones. Something to think about if your putting all new parts in the housing.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is offline
Old 04-08-2011, 12:26 AM   #17
Captainfab
60-66 Nut
Thanks for bringing this up.
Inspecting your axles is a good idea anytime they are removed from the housing, particularily the axle/wheel bearing surface. With the semi-floating design of the typical GM rear differential, the axle itself is subject to wear, since it is the inner race of the axle/wheel bearing.
If your axles are showing some wear, and you are also looking at upgrading to rear disc brakes, you might consider a set of aftermarket replacement axles. This way you can solve your axle/wheel bearing issue, the hub register issue as well as upgrade to larger 1/2" wheel studs all at the same time.
Old 04-18-2011, 03:13 PM   #18
tmoble
instead of turning down the hub why couldn't a guy open up the hole in the rotor?
don't forget guys, you'll need longer studs as the rotor is much thicker than the face of the drum.
tmoble is offline
Old 04-18-2011, 08:51 PM   #19
PGSigns
PGSigns's Avatar
Turning it down also adds lots more wheels to the list of wheels that will fit. I put torgue thrust 2's on mine and had to do the same thing to get the wheels to fit.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline
Old 04-18-2011, 11:20 PM   #20
Captainfab
60-66 Nut
There are a couple reasons to turn down the axle flange. One as mentioned by PGSigns, is more wheel selection. Second is if you were to machine the rotors to fit the axle flange, you would have to pay to do this every time you need a new rotor. Granted it won't be that often that you will need to replace the rotors, but just machine the axle flange and only pay once for the machine work. Also as I mentioned in my original post, I recomend upgrading to the larger and longer 1/2" wheel studs. The axle needs to be removed to do this properly, so you might as well have the register on the axle flange turned down while they are out. The rotor is only about 3/16" thicker than the drum. The need for longer wheel studs will depend on the wheels being used.
Old 04-24-2011, 05:58 PM   #21
Last_Paladin
Do you have a part number for longer studs? I could use 'em.
Last_Paladin is offline
Old 04-24-2011, 09:46 PM   #22
Captainfab
60-66 Nut
I don't have a part number with me here at home. The studs I used in the pic above were just stock studs for a '73-'87 C10. I don't have the length of them off hand. How long of studs do you need?
Old 04-26-2011, 02:07 AM   #23
Captainfab
60-66 Nut
The wheel studs I used in the pics above are the replacement studs for the '71-'86 C10's and also the '85-'94 Astro/Safari vans. They are Dorman #610-138 which are 1/2"-20 x 1-17/32" long. These extend past the rotors 15/16". If you want to stay with the original size of 7/17"-20 studs, then use Dorman 610-168. Those are 7/16"-20 x 1-1/2" long.
Old 04-27-2011, 11:05 AM   #24
m6z
m6z's Avatar
Is a ebrake an option on these?
Doug
Looking for a 67-72 short bed driver.....
m6z is offline
Old 04-27-2011, 10:47 PM   #25
Captainfab
60-66 Nut
The '93-'97 F-body rear calipers only come with a built in e-brake.
Closed Thread
