Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-15-2011, 01:16 AM   #1
05crewcab
05crewcab's Avatar
iPod direct to amplifier??
Has anyone done this? I dont have any desire to listen to the radio, or play CD's or anything like that. I just want sound from my iPod. I am thinking if I get a mini-jack to RCA cable can't I just hook it up directly to a 4-channel amp?
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 02-15-2011, 03:51 AM   #2
biasracing
biasracing's Avatar
Re: iPod direct to amplifier??
yes sir I have done it before. You can connect the ipod directly to an amplifier via the 3.5mm jack to rca, or there are cables that connect from the ipod interface to rca's. The volume will not be as "amplified" as it could be and you want good strong signal. It would be beneficial to run the signal through a line driver, eq, powered crossover, or some other interface "audio control, audison"
B.I.A.S Racing
7208 Bloxom Park rd
BMR2 BLG 3
Kennedale,tx 76060
800-979-0263 shop
866-936-1242 fax
info@biasracing.com
Website
facebook
twitter "follow me"
Authorized Dealer:AUDIO
Ascendant Audio
Alpine
DB Drive
Audio Control
Macintosh and anything else in between.
RIMS:
Check out Pros Designs TNT MHT Godspeed Atlanta Direct and more !
biasracing is offline   Reply With Quote
Old 02-15-2011, 02:38 PM   #3
jimmydean
jimmydean's Avatar
I have done this and will be doing it again shortly. Just run a 12v switch to power the amp on. You can get the signal amplifiers that might work well, but mine went plenty loud before and with 800w RMS, I don't think I'll have an issue this time, either.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-15-2011, 02:42 PM   #4
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Mini jack to RCA works fine, I have done this before, but you won't get as good quality sound going through the mini jack as you will through the dock connector.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 02-15-2011, 03:35 PM   #5
05crewcab
05crewcab's Avatar
Thanks Guys,
I just figured it was SO much easier hiding just an amp under the seat than trying to hide a headunit and getting a remote, and blah blah blah all set up when all i need is iPod...
are there Dockconnector to RCA cable adapters? I have only seen the mini-plug to RCA
1971 C-20 350/350
Old 02-15-2011, 03:56 PM   #6
GCncsuHD
GCncsuHD's Avatar
Yes, and no. They don't work with some newer generation Ipods
ΜΟΛΩΝ ΛΑΒΕ
Old 02-15-2011, 05:03 PM   #7
jimmydean
jimmydean's Avatar
I don't have an iPod (I hate iTunes and all other Apple crap, sorry) so I just use a headphone to RCA out of my MP3 player. Hell, I did that in my '69 VW in 1988 using a Rockford Fosgate Punch 75 amp and a Sony Sport Walkman
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-15-2011, 06:24 PM   #8
AceX
>130dB Moderator
AceX's Avatar
As mentioned, you CAN do it, but it is not the best way to do it. You have very limited ability to tune, and the signal coming from the iPod is just a few millivolts. You'll send the amps into clipping very quickly. Clipping = bad
My friend Fred from Arc Audio has done several high end systems using the iPod as the only source. Here's his email reply when I asked him about this subject:
Originally Posted by Fred Lynch, Arc Audio
We have done quite a few systems with the use of a IPOD of IPAD as an interface....
The most important thing here is to not use the headphone jack as the audio out on the system. We have exclusively used some parts from PAS/Peripheral company to accomplish the best sound out of these applications.....
We use a part called IS-76 which uses the 18 pin cable on the bottom of the Ipod or Ipad..... then we use another piece called the LC-1 which is a inline RCA based level control..... ... Then typically we will use an item line a XEQ or KEQ7 processor so we can have some tuning for the system and also to bump up the voltage into the amplifier since the Ipad and Ipod's only have milivolts of power to provide as signal power..
Then right into the amplifier...
Hope this helps..
Fred LynchArc Audio Inc
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 02-16-2011, 12:33 AM   #9
05crewcab
05crewcab's Avatar
Thanks for all the responses. I now have some direction, although it seems it isnt as straight forward as I had hoped.
1971 C-20 350/350
Old 02-16-2011, 03:31 AM   #10
jimmydean
jimmydean's Avatar
Interesting, I don't have an iPod, but my Sansa MP3 player didn't cause issues in my last system at all with clipping. Granted, I'm not showing my system, but I also know how to tune it, too. And maybe I just got lucky.
My '66 will be an interesting test since it might get shown a little when it's all done. I'm not saying the audio jack is the best way, just the easiest.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-16-2011, 12:56 PM   #11
05crewcab
05crewcab's Avatar
Doesnt it depend on the input sensitivity of the amp? The Alpine I have goes down to 0.2V which is where your output from your mp3 player must be? iPod must put out alot less than that...
1971 C-20 350/350
Old 02-16-2011, 03:06 PM   #12
jimmydean
jimmydean's Avatar
200mV is what my amp is rated for. I know the max voltage of the iPod is like 2v vs 5v for most decks, I'll measure my Sansa tonight and see. I am about a month out from installing, but I'll measure and see.
My VW was a walkman, my Grand Prix was a discman, 'cuda was also a discman, and in my Toyota I used a minidisc player. I used the Sansa in my last system and plan to use it initially in my '66 until I get my dash finished.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-16-2011, 03:55 PM   #13
65Gregg
65Gregg's Avatar
Here is a thread on this very thought, it was posted on the HAMB. I am sure there are variations but as everyone has, said it will work..
http://www.jalopyjournal.com/forum/s...d.php?t=548824
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 02-16-2011, 06:02 PM   #14
jimmydean
jimmydean's Avatar
I measured .35v out on my MP3 player. While far from ideal, it's above the minimum and again, I've never had issues. While I use my MP3 player as a source, I still spend for good hardware, so that might be why I don't have issues.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-16-2011, 06:27 PM   #15
05crewcab
05crewcab's Avatar
found this chart on the level the ipod outputs...
http://beavishifi.com/articles/headphonejack/
Ipod headphone jack 2.84 V
Ipod line out jack 2.94 V
Apple Universal Dock "Line Out" 2.01 V
Typical component CD player Line Out 5.76 V
this couldn't be right could it??? if so i would think it should work with just about ANY amp and sound decent with no clipping...
can anyone measure thier own??
1971 C-20 350/350
Old 02-17-2011, 07:08 PM   #16
AceX
>130dB Moderator
AceX's Avatar
Off the bat, I'm going to advise taking those measurements with a grain of salt. These are maximum outputs, not the point where they will go into clipped power or be sending tons of distortion down the line.
Living Life @ 130dB
RIP El Jay
Old 02-18-2011, 09:47 PM   #17
cjracer96
cjracer96's Avatar
ya. i kinda want and ipod hook up for like a casset player for my truck
'72 3/4 Ton 402 GMC (El Jay's ride)
cjracer96 is offline   Reply With Quote
