Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-27-2011, 01:10 AM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Behind the seat subwoofer box pics
Can I see some pics of different sub boxes made to go where the stock tank is. Finally ready to tackle this part of the truck.
1971ChevyTruck is offline   Reply With Quote
Old 02-27-2011, 01:17 AM   #2
Robertjust777
Re: Behind the seat subwoofer box pics
im looking to do a custom fiberglass box but i have seen one done here on the fourms but. i dont remember who it was but it was nice and im looking to do something like it im sure people will post some pics soon
Robertjust777 is offline   Reply With Quote
Old 02-27-2011, 10:25 AM   #3
squirel
squirel's Avatar
Not really a box but here is mine
In some foreign language "merge" means to stop and turn your head left.
My build page
http://67chev.shawwebspace.ca/
squirel is offline   Reply With Quote
Old 02-27-2011, 12:25 PM   #4
stich626
I like that,, it's so K.I.S.S.
IS the side speakers 6 by 9"s
did you block off the area above, that runs beside the rear window,,
stich626 is offline   Reply With Quote
Old 02-27-2011, 12:47 PM   #5
squirel
squirel's Avatar
yes they are 6X9 's. I was out at our local pick n pull looking for the speaker covers and found a Pontiac Sunfire door pads and cut them out out and then as I was walking back there was a 95 Cadillac with Bose speakers in it. Cost me 12 dollars for all of it As for the area above, that runs beside the rear window. I am not sure of which area you are referring to but maybe this picture will help
My build page
Old 02-27-2011, 05:09 PM   #6
Red68
Red68's Avatar
Here is mine, not quite as fancy as Squirels, I like what he did in the corners. My custom made kick panels have 6 1/2".
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 02-27-2011, 09:35 PM   #7
1971ChevyTruck
Both of you gave me some ideas. Squirel how does the sub sound in that?
Old 02-27-2011, 10:18 PM   #8
Jparks
Jparks's Avatar
Red that's a clean simple setup, probably gonna end up doing something similar
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast"
68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger"
Jparks is offline   Reply With Quote
Old 02-27-2011, 11:40 PM   #9
squirel
squirel's Avatar
The sound is good but do not have the seat in yet. It shakes the dust of the truck
My build page
Old 03-01-2011, 09:24 PM   #10
DrtyJack75
any dimensions on your box? air space? Im debating my system right now.
DrtyJack75 is offline   Reply With Quote
Old 03-03-2011, 08:29 AM   #11
finadic
heres mine
finadic is offline   Reply With Quote
Old 03-03-2011, 01:05 PM   #12
DrtyJack75
Originally Posted by finadic View Post
heres mine
How did they round the corners, is it fiberglassed?
That's nice...how's it sound?
Old 03-03-2011, 01:51 PM   #13
jimmydean
jimmydean's Avatar
I just started roughing out my box and amp rack since the amp I was going to use seems to no longer be available. As soon as my fuel cell gets here, I'll pull the tank for good and start the long process.
2 amps, 2 10's, and 2 6.5's will be behind the seat.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-13-2011, 10:23 PM   #14
Bad70sbchevy
Bad70sbchevy's Avatar
Here's mine. 2 Fullsize 12" Pioneer Subs, 300W Jensen Amp, fan cooled enclosure.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 03-14-2011, 08:40 PM   #15
DALTON
69 C-10 Short Fleet
DALTON's Avatar
heres mine
do you have any close up pics of the top seam and the corners? is it glassed? thanks in advance for the info,,Im trying to figure my corners & the top seam out now
Tony Dalton
DALTON is offline   Reply With Quote
Old 03-15-2011, 05:50 PM   #16
entourageguy
Yellow truck club
entourageguy's Avatar
Do the subs need an open port in the enclosure? Are there certian size areas for the subs according to size of sub?
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 03-15-2011, 07:39 PM   #17
Bad70sbchevy
It all depends. There are two types of boxes, ported and sealed. Ported boxes have openings in the box that allow the box to "resonate" producing more base at a specified frequency depending on the opening. You can get very carried away with different formulas for tuning these kind of boxes (sometimes the manufacturer will give specs for a typical opening), but the simplest boxes and most popular is the sealed box (what I did). These boxes have to be air tight or sealed to work. As for the box volume, usually the manufacturer will specify a volume for the box. Shape usually doesn't matter, or if it does its not enough to make a difference generally. One thing to note though usually the manufacturer gives a range of volumes. Smaller volumes produce tight base which is good for rock music and bigger boxes tend to give a loose or lower base typically perfect for rap music.
Old 03-15-2011, 07:42 PM   #18
entourageguy
Yellow truck club
if your doing 2 subs in an enclosure should they be divided or can they share the same space?
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 03-15-2011, 07:55 PM   #19
Bad70sbchevy
I believe they can share the same volume (someone double check me though) as long as there in phase (they go in and out at the same time, if you wire them up the same they should be) and they are the same kind of sub woofer. I want to say you would use double the volume of a single sub though since the subs are displacing twice the air. On mine though I just went ahead and ran separate volumes.
Old 03-15-2011, 10:41 PM   #20
stich626
in a sealed box, divide..
ported either way, but I divide
Old 03-15-2011, 11:46 PM   #21
Bad70sbchevy
Just out of curiosity, why does a sealed box have to be divided?
Old 03-16-2011, 03:05 AM   #22
1986swb
1986swb's Avatar
Here's my recent installation. Pioneer 12" flat subwoofer (TS-SWX310). Rated at 1000 watts. In the last pic, I re-routed the bottome amp wire behind the amp board and driver's side speaker bracket for a cleaner look. Just didn't get a chance to take a new pic.
1986 GMC Sierra Classic C1500 SWB
2006 GMC Yukon Denali
http://67-72chevytrucks.com/vboard/a...hp?albumid=977
1986swb is offline   Reply With Quote
Old 03-24-2011, 06:34 PM   #23
TurboSixPiston
2 sharing the same volume in an enclosure (be it sealed or ported) is doable and will not inherently damage the speakers, and won't automatically sound bad either. JL has sold boxes like this so it's not a "do it and you're a loser" type of deal.
However, the problem with it is that you need more volume than you would for one sub. This could potentially lead to over excursion and damage to the subs because of the loss in suspension control, particularly in vented enclosures. This possibility depends on how much power you are sending the subs, and the size of the airspace. Compound loaded enclosures do not apply to this.
So, it's not all that hard to put a board down the middle of the box and create seperate sealed chambers, and it is good insurance regardless of the type of box. You would need to add a second vent in a ported enclosure.
Two subs will only be louder than one sub if you give them both a greater total amount of power as you did the first sub in the beginning. This is because adding another sub to one that is recieving 100 watts will divide that power between them, now making 2 subs with 50w each. To increase the sound output over the one that was taking 100w, you will need to add more power. This is assuming you're using a single channel amp.
I can't imagine anybody wanting more than one well powered sub in a sealed box, especially in trucks with a teeny cab like ours. Properly done single sub output can exceed the threshold of pain.
To those of you unsure on how or why to properly construct a box, see number 110 in the directory on the side of this page. http://www.bcae1.com/
It is a good site to bookmark if you are building your own system and have questions about the process.
I didn't mean for the post to be so long winded, but there is a tremendous amount of depth to the subject. You never know it all, no matter how long you've been doing it.
TurboSixPiston is offline   Reply With Quote
Old 04-09-2011, 02:02 PM   #24
67cheby
67cheby
67cheby's Avatar
here is some progress pics of mine will be fiberglassed smooth on the front matching the cab contours and contouring the speaker rises back into the box
67cheby is offline   Reply With Quote
