Old 03-06-2011, 08:17 PM   #1
McNugget
McNugget's Avatar
Question How to make my 71 chevy a 4x4?
I have a 1971 Chevy Cheyenne that I bought a 4x4 frame for. I need to buy new cab mounts and springs and I am looking for linkage to the transfer case and a front driveshaft. I will be able to at least set my truck on the 4x4 frame and just leave it until I find the parts, so it'll only be 2WD. But I am wondering about how much time this conversion will take of just setting the cab and motor and everything on the frame and mounting it up so I can still drive it? and is there anything else I will need to buy...any advice?
McNugget is offline   Reply With Quote
Old 03-06-2011, 08:45 PM   #2
63chevyll
gets board easy.......
63chevyll's Avatar
Re: How to make my 71 chevy a 4x4?
Depends what all your new frame has. Is it just a frame or complete with suspension and.axles
63chevyll is offline   Reply With Quote
Old 03-06-2011, 11:07 PM   #3
McNugget
McNugget's Avatar
Well, I am not 100%, I am a girl and don't know everything about all this stuff. but I'll tell you what I know to the best of my knowledge. It came with a transmission and NP 205 Transfer case. I will have to get the linkage made to fit the transfer case because it does not have any. It doesn't have cab mounts and it does sit on both axles and has wheels and tires on it. I have a picture...its not the best but maybe it'll help!
Old 03-06-2011, 11:29 PM   #4
onebadbowtie
onebadbowtie's Avatar
depending on what transmission that was in the truck that your cab off of you might need a high hump transmission tunnel and possible clutch pedal assembly also
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 03-06-2011, 11:31 PM   #5
McNugget
McNugget's Avatar
Well the tranny I have now is a 350 small block auto. and The one that came on the truck, I was told is the exact same. I am going to have it looked at of course, but I'm hoping for the best...
Old 03-07-2011, 12:04 AM   #6
onebadbowtie
well you wont need the clutch assembly then...just the high hump transmission tunnel
James
Old 03-07-2011, 12:26 AM   #7
McNugget
McNugget's Avatar
Is the tunnel hump something I can find aftermarket or something ill have to buy off of the parts page?
Old 03-07-2011, 12:37 AM   #8
63chevyll
63chevyll's Avatar
You can look on here or check local wrecking yards. As for the body mounts, you can buy a new set or try and reuse your old ones.
Does your frame have steering box and steering.
Also, are you planning on any kind of lift
Old 03-07-2011, 10:48 AM   #9
McNugget
McNugget's Avatar
Well I know ill have to get new cab mounts which I know I can get LMC. I do have power steering and brakes and the 72 frame has a 4 inch lift already on it.
Old 03-07-2011, 03:54 PM   #10
Gene
Gene's Avatar
If the turbo 350 you have came out of a 2wd truck you will need to have a 4wd main shaft installed. I know, I had to do this on mine because the tailshaft was too long to mate up to the transfer case. Might be a better idea to try and locate a 4wd transmission?
Gene is offline   Reply With Quote
Old 03-07-2011, 04:04 PM   #11
71swb4x4
71swb4x4's Avatar
PM boardmember joesjunk, he has done several body swaps and they turn out very nice. He is in Indepence, MO so he is fairly close to you too.
Here is one: http://67-72chevytrucks.com/vboard/s...d.php?t=313007
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-07-2011, 04:58 PM   #12
swampfox
swampfox's Avatar
Unless I read it wrong, if the cab is set up for a automatic the hump will not need replaced .
69 gmc 4x4 lwb 327 4sd not running
swampfox is offline   Reply With Quote
Old 03-07-2011, 05:02 PM   #13
McNugget
McNugget's Avatar
really? yeah my truck now is automatic and the one on the frame is an automatic 4x4 transmission as well- correction from earlier posting. I didn't mean to make it sounds like its identical to mine, just meant its automatic like mine now.
Old 03-07-2011, 06:05 PM   #14
swampfox
swampfox's Avatar
I should have said that unless you go to a 4 spd the floor hump will clear . I swapped a cab that was set up for a auto ,to a frame with a 4 spd and had to install a taller hump.
Old 03-07-2011, 08:31 PM   #15
onebadbowtie
i was under the impression that any 4x4 had to have the high hump to help clear the transfer case also not just the tranny but i may be wrong
James
Old 03-07-2011, 08:46 PM   #16
haysonj
haysonj's Avatar
You can actually lower the rear mount with spacers and it will help the pinion angle on a lifted truck. She said it has a four inch lift already and she already has the transmission/ transfer package in the frame.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-07-2011, 09:09 PM   #17
Gene
Gene's Avatar
Thats what I thought too, but after cutting mine out it looked like a low hump would have had plenty of body to case clearance. I cut mine anyways because I already bought a high hump, and already had new high hump carpet.
Old 03-07-2011, 09:45 PM   #18
trevrolet65
It's a good bit of work transfering all your parts onto that frame. Your truck will be down longer than you think, it always happens due to I need to fix this first. Sounds like you have most of the parts, sounds like a cool build.
trevrolet65 is offline   Reply With Quote
Old 03-08-2011, 08:54 AM   #19
duallyjams
duallyjams's Avatar
Is the pic in your profile your truck that you are converting ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-08-2011, 09:10 PM   #20
McNugget
McNugget's Avatar
Yeah its a teal and white colored truck but I am planning to eventually paint it red. I know it will be a lot of work, but I'm hoping, with fingers crossed that it wont be much more than a couple weeks at most. I don't have to actually do the 4x4 parts yet because it is summer time soon and I wont need them til next winter, so that gives me all summer to find them!
Old 03-09-2011, 09:43 AM   #21
duallyjams
duallyjams's Avatar
Can you post more pics of your 4x4 so we can see exactly want you need and don't need to do.
James
IG duallyjams
Old 03-09-2011, 06:26 PM   #22
72longbed
72longbed's Avatar
Thumbs up Re: How to make my 71 chevy a 4x4?
Like duallyjams said, we could use a whole bunch more pics of your 4x4 frame, front to back, and that will tell the story. From what I can see of your 4x4 frame, you may already have most of the "parts" that will make that baby go .... Of course, you need to swap in your engine.
I have done a couple of 4x4 builds from 2WD trucks to 4x4 frames, and it isn't that difficult. I am going to say that most of what you may still need can be found right here on this site. The correct 4x4 Turbo 350 and transfer case is already in your 4x4 frame. You will just want to verify the condition of both. NP205's are pretty much hard to kill, but that Turbo 350 could have some issues. Drop the pan and inspect the fluid that comes out and also whats left in the pan (shavings, small parts, etc.), and have it (the transmission) flushed thoroughly including the torque converter. The cab mounts ARE different for a 4x4 truck vs. a 2WD truck. They are also different for a 3/4 ton 4x4 vs. a 1/2 ton 4x4. Did my homework on that one.
If you truly have a 1972 4x4 frame, you've got the best setup that Chevy put under these trucks. But as stated before, . (not really worthless ... but pictures sure are worth thousands of words!!)
It's going to be a fun project for you and we'll all help.
72longbed
72longbed is offline   Reply With Quote
4x4, 71 chevy
