Old 03-10-2011, 11:21 PM   #1
'68 Pieces
'68 Pieces's Avatar
removing bedside help
Hey everyone, im trying to remove my passenger side outer bed panel on my 68 . Ive got the bolts loose, but im sure as some of u know, u can only loosen them so far and then they just start to spin. So do u attach vise grips to the inside? Or are their some other methods u have tried that work?
Also if anyone has some pics of the actual removal of the outer bed panel that would be great, i understand the basic concept of how it is on their, but im sort of afraid that removing it i wont be able to get it back on their right haha, so if anyone has any advice or pics of the removal process/ putting back on that would be very useful right now lol
Thanks for any info
1968 Chevy short bed restoration/ build/ put back together/ whichever you wanna call it!
I shall call it :"Rusty Tomato": its in the works
" Anything free is worth saving up for "
" If you dont know where to start, go back to the beginning "
'68 Pieces is offline   Reply With Quote
Old 03-11-2011, 12:07 AM   #2
67chevy1series
67chevy1series's Avatar
Re: removing bedside help
i would mark how many bolts and what size they are and get the exact ones from lowes then go out and grind all the bolts off take the bedside off do whatcha got to do then bolt it back on with the new bolts
67chevy1series is offline   Reply With Quote
Old 03-11-2011, 12:45 AM   #3
sameyrasmea72
sameyrasmea72's Avatar
Too late now, but I usually tighten the bolts till the snap. Also, don't forget the four hidden bolts at the rear bottom (don't tighten them off) or the 2 spot weld on both sides.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 03-11-2011, 09:57 AM   #4
'68 Pieces
'68 Pieces's Avatar
thanks guys
Ya, i thought about maybe tack welding the top of them in place, but i wanna be able to take them out completely.
I may have to end up just cutting them all off, I really dont wanna have to but........... i may have no choice.
Old 03-11-2011, 10:29 AM   #5
JORGIE95961
Originally Posted by '68 Pieces View Post
thanks guys
lol .. i tacked them on. it worked... but if you havenjt tried them all the best way is to tighten them and have them brak.. either way your bolts are ruined..... not a bad sacrifice for lots of time...
JORGIE95961 is offline   Reply With Quote
Old 03-11-2011, 01:01 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I also tacked all mine in place.. Dont forget to cut the weld from the factory on the rear bedside area near the tailgate hinge..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-11-2011, 01:17 PM   #7
stich626
anyone have a pic of where those spot welds are..
stich626 is offline   Reply With Quote
Old 03-11-2011, 01:25 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
I don't have a pic but its right at the lower rear corner of the bedside and bed floor ... Hope that makes sense..
MEMBER #6377
Project "7DEUCE"
Old 03-11-2011, 01:28 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Yup. Just drop your tailgate and you will see them.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 03-11-2011, 01:49 PM   #10
stich626
on the part facing the bumper or the cargo floor
Old 03-11-2011, 02:35 PM   #11
FRENCHBLUE72
PROJECT 7DEUCE
hope this helps...
MEMBER #6377
Project "7DEUCE"
Old 03-11-2011, 02:54 PM   #12
rpmgroup
weld nuts on top of the carrige bolts and use a wrench to keep them from spinning and rounding out the square holes.
rpmgroup is offline   Reply With Quote
Old 03-11-2011, 02:58 PM   #13
leddzepp
Moderator
leddzepp's Avatar
This is the best and easiest way to remove them.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 03-11-2011, 07:52 PM   #14
sameyrasmea72
Another pic!!!
72 Cheyenne Super
Old 03-12-2011, 03:51 AM   #15
'68 Pieces
'68 Pieces's Avatar
Thanks u guys for more info.
i tried the whole tightening them down thing, and it worked for some.
Some of them though i tightened down and then the nut just began to spin, i think it may have just spun the threads off.
Some of them i latched onto with a pair of vice grips, and bent them back and forth till they broke, lol.
A couple are stubborn though, im gonna have to try and weasel a slitter wheel in their or something, i think its gonna be harder then i imagine though......
Old 03-14-2011, 10:19 AM   #16
JORGIE95961
i JUST TORE APART A LONGBED LASTNIGHT.. I WILL BE CUTTING THE FLOOR DOWN TO FIT MY SHORTBED... THE BOLTS THAT DIDNT BREAK , I just ground the heads off and ponched them through
Old 03-14-2011, 11:23 AM   #17
eagleuh1
eagleuh1's Avatar
put a nut splitter on the ones you can.
eagleuh1 is offline   Reply With Quote
Old 03-14-2011, 03:33 PM   #18
'68 Pieces
'68 Pieces's Avatar
thanks guys, Yes i had to take the grinder to some of them.
