Old 03-25-2011, 02:22 PM   #1
gman72
Speedometer Correction 205
Hey, I have a NP 205 transfer case and I am about to go up in tire size to a 33 inch. I was just wondering what would be the easiest way to correct my speedometer. Post a link or leave a response, Thanks
gman72 is offline   Reply With Quote
Old 03-25-2011, 03:40 PM   #2
jasons
not enough hours in the day
jasons's Avatar
Re: Speedometer Correction 205
I don't think you can change the speedometer gears in the transfer case like you can in a transmission. I've used ratio adapters like these.http://www.transmissioncenter.net/sp...atio%20adapter
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 03-25-2011, 03:58 PM   #3
Keith Seymore
Keith Seymore's Avatar
x2 on the adapter.
Just figure out your actual speed (using a GPS or one of those radar signs) and compare it to your indicated speed.
Buy an adapter of the appropriate ratio, plug it in and you're good to go.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
correction, speedometer
