Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 11-26-2008, 08:49 PM   #1
dgram8
Steering wheel resizing
has anyone ever seen a smaller version of orginial steering wheel possibly aftermarket
dgram8 is offline
Old 12-07-2009, 10:09 PM   #2
Don Smith
Re: original steering wheel
I cut one down to 15 inches and took pics of process . Will post pics when I figure out why not posting corrrectly.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline
Old 12-08-2009, 03:39 PM   #3
Don Smith
Steering wheel cut and bent to new dia
96 Impala SS
97 Monte Carlo
Old 12-08-2009, 03:56 PM   #4
Don Smith
Rim welded together with new spoke locations cut out
96 Impala SS
97 Monte Carlo
Old 12-08-2009, 04:01 PM   #5
Don Smith
Had to add extensions to spokes because I cut spokes too short. They should be cut flush with rim.
96 Impala SS
97 Monte Carlo
Old 12-08-2009, 04:10 PM   #6
Don Smith
Welding process
96 Impala SS
97 Monte Carlo
Old 12-08-2009, 04:16 PM   #7
Don Smith
Using filler and shaping
96 Impala SS
97 Monte Carlo
Old 12-08-2009, 04:20 PM   #8
Don Smith
Finished product. Sorry about individual pic post, could not get them to post all at one time.
96 Impala SS
97 Monte Carlo
Old 12-08-2009, 05:28 PM   #9
nds1968
nds1968's Avatar
I like it. You got me thinking. Did you use regular body filler?
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline
Old 12-08-2009, 06:02 PM   #10
Don Smith
I used epoxy on cracks and then covered and feathered with Bondo. I used Bondo on the big gaps. PC-7 Epoxy would also be a good choice instead of Bondo. (this is and old spare wheel). This is first one I've tried.
Note: the steel ring is made from hardened steel and I used two Bosh metal cutting jig saw blades to cut.
The outer material is similar to hardened rubber but will not crack when bent to size.
I cut the spokes initially with a stub on the rim, but side spokes move up in rim when it is resized and should be cut flush . If I had done this I would not have had to weld extensions on spokes. Will be glad to answer any questions.
96 Impala SS
97 Monte Carlo
Old 12-22-2009, 11:40 PM   #11
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Ok I just saw this thread and I have a question. Do you think that a smaller diameter late model steering wheel would work instead of cutting up the original? I'm thinking a weekend project in in the near future.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline
Old 12-23-2009, 01:02 PM   #12
Don Smith
nickp51chevy: I have used an 80's model Camero wheel that is a direct fit and is 14and 1/4 inches in diameter. I have also used a 90's Chevy truck wheel and it is 15 and 1/2 inches in dia. and does not require modification to fit.
96 Impala SS
97 Monte Carlo
Old 03-18-2011, 05:12 AM   #13
slick copper
slick copper's Avatar
That looks awesome. I really really wanna do this to my steering wheel. Have you tried it on a truck? Is it centered?
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline
Old 03-18-2011, 08:12 PM   #14
Don Smith
I put this on my truck after I completed it. I really like the smaller diameter. I tried several other wheels (Camero, 90's truck, Grant) but I like this style. If I do another one I will make the cut in the wheel at the bottom where the spoke attaches after I have cut spokes out of course. I will also cut the spokes as close as possible to the rim so I wont have to weld pieces back to spokes. I can then trim the spokes if necessary. Plan on using several metal cutting blades, the core is hardened steel.
96 Impala SS
97 Monte Carlo
Closed Thread
