Old 07-01-2011, 12:26 PM   #1
haskell
haskell's Avatar
Burb upper trim removal
I am prepping my 70 for painting. Does anyone have any suggestions on removing the upper trim without damaging it too much.
Do folks try to get behind the sheet metal or use prying?
Any thoughts would be appreciated.
1969 Chev Longhorn Custom Camper
1955 Buick Century Estate Wagon
1963 Buick Riviera
1953 Chevy 3100 Panel
1967 C-20 V8 4 speed
1951 Willys Jeep Wagon
1956 Chevy Suburban
haskell is offline   Reply With Quote
Old 07-01-2011, 12:40 PM   #2
Tim240Z
Tim240Z's Avatar
Re: Burb upper trim removal
I just pulled all mine off yesterday. Apart from the few screws at the ends, I just used a very thin 2" wide scraper....it is thin enough to flex and I used it to push the side 'spring' clip tabs and just popped them out.....pretty easy once you get it going....I tried squeezing the clips from the inside, but it seemed a lot harder and more time consuming.....
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 07-01-2011, 08:13 PM   #3
haskell
haskell's Avatar
I appreciate the prompt post.
1963 Buick Riviera
1956 Chevy Suburban
Old 07-01-2011, 11:22 PM   #4
burbguy
burbguy's Avatar
hey does anyone on the board know where to get new clips..? I heard they don't make new aftermarket ones, or can you use ones from the 60-66 side moulding on the trucks..?
Shawn
1966 short fleet 230 I-6 three in the tree (daily driver)
1966 short fleet big block th400 (building slowly)
1972 c10 3 door suburban 350 th350 (building faster than slowly)
2004 F250 power stroke (not dependable enough to be a daily driver)
2005 Kenworth T-800 Heavy Haul tractor (that's my true daily driver)
burbguy is offline   Reply With Quote
Old 07-01-2011, 11:48 PM   #5
Tim240Z
Tim240Z's Avatar
I believe that they are the same as the truck upper tailgate molding clips.
http://www.truckandcarshop.com/ part number 67-09104
1972 Suburban C20
