Old 08-04-2011, 02:05 PM   #1
mud slut 350
mud slut 350's Avatar
350 sbc stack fire
So heres how the story starts. I was out trail riding all was well truck was running great. progressively the truck would start to stack fire when i gave it gas and it was under a load. after progressively getting worse for about an hour it finally got to the point where if i even touched the gas she would die out but would idle fine. we pulled the distributer off and cleaned all the contacts with a rag since there was a little bit of corrosion on them and a lil damp also. we put it back on and she didnt even start. just turned over and lit the carb on fire. so obviously timing was jacked up. we advanced the timing (turned clockwise) and she fired up and ran, although had some spark knocking she got us out of the trails and home. at home pulled the vac advance off and found it was bad replaced it and set the timing to 8deg with the vac advance unhooked and plugged and the line was rock solid at 8 not jumping around at all. that was about 2 weeks ago now it still stack fires really bad when under any load even though the timing is still rock solid at 8 deg. I dont know where to go from here think it could be a tuning problem? It has a edeljunk 650 on it that hasnt been touched in about 6 months or so. any help would be awesome! also am thinking about putting a regular HEI dist on it to get rid of the esc bull. So if anyone has any comments on that also... truck is an 82 k10 350 sbc,sm465, np205, dana 60 front, 14bff rear.
mud slut 350 is offline   Reply With Quote
Old 08-04-2011, 02:32 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: 350 sbc stack fire
can you explain "stack fire" that's a new one on me.
My first question would be,, even tho it appears to be a ignition problem, are you SURE you have clear fuel filters and fuel delivery, a carb that isn't experiencing float issues... etc.
For an HEI to act randomly wild,, it's almost 99,9% of the time got to be module inside the distributor, OR a bad wire feeding that module.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-04-2011, 02:39 PM   #3
mud slut 350
Stack fire as in firing out the carb through the intake manifold. yeah my next thing is the fuel filter but i just wanna get rid of the esc computer and all the wires its just more mess and i dont wanna deal with it anymore. and its in the way under the dash.
Old 08-04-2011, 02:40 PM   #4
mud slut 350
is there another term instead of stack fire? thats just what me and my freinds have always called it.
Old 08-04-2011, 03:04 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Carb backfire...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-04-2011, 03:51 PM   #6
stich626
sticking or burn valve, or your timing chain jumped a tooth or two
stich626 is offline   Reply With Quote
Old 08-04-2011, 06:39 PM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
potatoe chips?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-05-2011, 12:24 AM   #8
raceman6135
Dino burner
raceman6135's Avatar
A lobe on the camshaft could be going/has gone flat.
raceman6135 is offline   Reply With Quote
Old 08-05-2011, 01:48 AM   #9
mud slut 350
Wth fast? Hahaha well next pay check im leaning towards a distributor because a couple other threads I found had similar problem and the springs in there ended up bein worn along with the bushings and stuff. Last resort after that plugs wires and carb tune I guess ill pull the cam and take a look at it.
Old 08-05-2011, 10:56 PM   #10
NuBomb
NuBomb's Avatar
I had a similar problem and finally pulled the plugs. 3 were oil fouled.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 08-06-2011, 10:12 AM   #11
stich626
only way to get fire in the intake is an open intake valve (burnt or sticking) or timing..
plugs won't do it.. bad wires allowing the ign energy to cross wires will tho..
carburetor, timing, tuning
