Old 08-19-2011, 07:21 PM   #1
DD1
Question Need help w/71 C10 project
I got a 71 C10 to work on as a project. The people I bought it from put in a Chevy 305 engine w/auto transmission, taken from an 85 (or so) Camaro. I am not thrilled about it being converted to automatic, but will live with it for now.
The carburetor is a Quadra Jet, which has a Mixture Control Solenoid, so my understanding is it won't work well without a computer hookup. What's the best manual choke carburetor to get for this truck?
Also, if I were to switch engine or trans, what's the best combo to get?
Thanks!
DD1 is offline   Reply With Quote
Old 08-19-2011, 08:28 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: Need help w/71 C10 project
Welcome to the board!! As far as the replacement engine/trans combo, there are so many different options it is hard to chose! Also, personal preference has a lot to do with it. Personally I like a big block and a TH400 trans...For a carburator, I like the edelbrock carbs. I have had very good luck with them.
Bob
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 08-19-2011, 08:34 PM   #3
DD1
Thanks for the response, much appreciated. I just joined the group. I was reading some of the other threads on here, and it seems like everyone is really helpful.
Old 08-19-2011, 09:51 PM   #4
67CC
There are a number of choices, like the man said. Earlier Quadrajets, from around the time of your truck would work well. They should bolt onto your manifold. Manual choke conversion kits are available from a number of sources. If you go that route, use a quality rebuild, not something off someone's junk pile. Probably be more trouble than it's worth.
'67 C20 Custom Camper. 327, three-on-the-tree. No power anything!
67CC is offline   Reply With Quote
305v8, c10, chevy truck, quadrajet
