Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-06-2011, 11:50 AM   #1
vikasintl
Question timing light does not shoot at steady 8
we have 1989 Gmc s15 truck 112k miles
when I check timing instead showing at 8 degree
it flickers between 6 to 10..sometimes 6 sometimes 8 or 10 etc.
same thing with vacuum ..flickers between 14 to 17 etc.
also when we start the truck it vibrates heavily and when stomp on gas pedal vibration stops...when we drive it does not vibrates..so am not sure...if this is due to engine mounts. I also think when engine is warm it does nor vibrates...
changed spark plugs, checked wires for resistance, cleaned cap and rotor...
what should be reason? and what's solution?
vikasintl is offline   Reply With Quote
Old 09-06-2011, 10:30 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: timing light does not shoot at steady 8
check for vacuum leak. IAC is attempting to bring things back to normal as well as ECM changing timing which accounts for fluctuating timing.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-06-2011, 10:37 PM   #3
BMERDOC
BMERDOC's Avatar
I would agree with 68C15, if it fluctuates its internal like a miss. Remember, there is such thing as a lean miss which would be where he is pointing you. Simply enough, it is an internal problem and not a problem with mounts or something similar.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-06-2011, 11:42 PM   #4
vikasintl
Question Re: timing light does not shoot at steady 8
Someone suggested to check for pressure regulator spring and its not broken...how do I check for vacuum leak?
also how do I check for IAC? if its working properly or something wrong there?
Old 09-07-2011, 06:35 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
spray carb clean, just a shot here and there. when the idle changes you have found it. you can also use a mechanic's stethoscope with just the hose to focus your hearing while you listen for a hiss.
the IAC is like the sheriff in town. if he is arresting a bunch of drunk drivers he is not the problem, he's just doing his job.
Old 09-07-2011, 04:58 PM   #6
vikasintl
Thanks I found a vacuum leak and fixed the hose and it runs smooth now..truck or engine is not shacking any more...thanks for advice..
I did not understand what you meant for IAC though...
Old 09-07-2011, 07:27 PM   #7
BMERDOC
BMERDOC's Avatar
IAC= Idle Air Control
Nick Carter
Old 09-07-2011, 07:45 PM   #8
95 S_Trucker
95 S_Trucker's Avatar
when you check timing, are you unplugging the timing connector under the pass. side carpet?
95 S_Trucker is offline   Reply With Quote
Old 09-14-2011, 03:45 PM   #9
vikasintl
We have 89 gmc s15 2.5 Liter ..does it have timing connector?
Old 09-15-2011, 08:13 AM   #10
Tink
Tink's Avatar
Yup, all computer controlled vehicles do.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 09-15-2011, 11:32 AM   #11
vikasintl
Can you point me to an image or video so I can see where is this timing connector ? I can't find under passenger side carpet...
Old 09-15-2011, 10:55 PM   #12
95 S_Trucker
its up close to the fire wall and kick panel. a single wire connector, i cant remember what color the wire is
Old 09-16-2011, 06:33 AM   #13
68C15
blood type; Retumbo
68C15's Avatar
tan with a black stripe
engine mounts, rough idle, timing, vibration
