Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-13-2011, 01:00 PM   #1
dliving69
dliving69's Avatar
Remote Start?
Any ideas on remote start for a 69 c10..Might have one soon to put in, just didnt know if it was really possible to do with a carburated engine. I heard its been done before plenty of times, Just didnt know the work that had to go into it? Anything will help with this decisions
dliving69 is offline   Reply With Quote
Old 09-13-2011, 02:37 PM   #2
dcasalena
dcasalena's Avatar
Re: Remote Start?
Interested in what the answer here is. I'm sure installation is not too bad, but making it work...?
I bet everyone has a different start routine, especially those of us still running older motors. I know I pump the pedal 2 times on a cold engine and a warm day and it starts right up, but 3 pumps and a few cranks on a cold day. If the engine is already warm, then it's a different process entirely. Unless the remote starter could give 3 pumps on the pedal before turning the starter, it would never work for me.
subscribed!
dcasalena is offline   Reply With Quote
Old 09-13-2011, 05:29 PM   #3
fixit-p
fixit-p's Avatar
Re: Remote Start?
I knew someone who did it on his 72' 442. He used an unused channel on the alarm to cycle a relay that controlled an actuator which pumped the accelerator and set the choke. I'll try and find out what type of actuator he used and where to buy it from.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 09-14-2011, 01:38 AM   #4
dliving69
dliving69's Avatar
Re: Remote Start?
Thank you fixit-p that would be great if you could get some info on that! Thanks!
Old 09-14-2011, 09:20 AM   #5
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Remote Start?
I own a car audio shop in Fresno. I am currently looking into this myself. As dcasalena has stated every truck may have a different starting routine. Mine you also have to pump the gas twice. There are a lot of variables involving the carb. The over all answer is yes this is possible. I'll be working on this within the next month or two. I believe it can be accomplished with out having to pump the gas, but I will have to play with my carb some to see if I can achieve this.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 09-14-2011, 10:09 AM   #6
fixit-p
fixit-p's Avatar
Re: Remote Start?
He said he used a solenoid from trombetta http://www.trombetta.com/solenoids-products.cfm?id=14 (doesn't remember which one) and used the aux channel on the remote to actuate it. Once the choke was set and the engine started he could hit the aux channel again to get it off of the fast idle cam, worked like a charm. This video isn't his install but very similar.
Old 09-14-2011, 01:02 PM   #7
dliving69
dliving69's Avatar
Re: Remote Start?
Thanks thats alot of help! im getting closer to getting this done and everything i can get will help!
1969 c-10, chevy c-10
