Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-15-2011, 10:10 PM   #1
ntd
big block into a '72 blazer ?? help
Ok I am now thoroughly frustrated and am asking anyone for a little help.
I am putting a big block 402 into my '72 k5, I have it in the hole and bolted in.
I am past the problems with firewall clearance and frame clearance with the headers and now I am trying to get my alternator and power steering pump installed.
I am finding a problem with the alternator clearing the valve cover and lining up with the pulley and then there is the power steering pump with remote reservoir.
that also doesn't appear to want to fit and line up... there just doesn't seem to be enough room between the frame rail and the pump....grrrr
does anyone know somebody who has put a big block into a k5 blazer and if so how did you get the accessories to fit.
thanks for any help.
ntd is offline   Reply With Quote
Old 09-17-2011, 12:35 AM   #2
bigblock68
bigblock68's Avatar
Re: big block into a '72 blazer ?? help
are you running a short or long water pump?i can take some pics and help you out,my blazer has a long pump.
bigblock68 is offline   Reply With Quote
Old 09-17-2011, 01:03 AM   #3
ntd
can I call you ?
Old 09-17-2011, 01:04 AM   #4
ntd
yours is a big block ?
I have a short water pump
Old 09-17-2011, 01:06 AM   #5
ntd
I would like to see a pic of your powersteering set up
I do see that you don't have the remote reservoir for pump...and your alternator is on the pass. side
where did you get the bracket for your alternator ?
Old 09-17-2011, 01:11 AM   #6
bigblock68
bigblock68's Avatar
i have a long pump so the alt. is on the rh side.i think all the trucks of this era had short pumps so there should be some good pics out there on the truck side.the ps set up is different for long pumps also.
Old 09-17-2011, 01:14 AM   #7
bigblock68
bigblock68's Avatar
i got the ps set up,motor mounts ,etc off a mid 70's truck.
Old 09-17-2011, 01:16 AM   #8
bigblock68
bigblock68's Avatar
the short hose from the water pump to the intake is available at your parts house...with a short pump its even a tighter bend.
Old 09-17-2011, 01:07 AM   #9
ntd
yours is a two wheel drive ? right ?
mine is 4x4 with a 4-speed
Old 09-17-2011, 01:09 AM   #10
ntd
what is the big difference besides the obvious between the long and short H20pump
Old 09-17-2011, 01:11 AM   #11
ntd
one more thing.....it's like being in a candy store seeing how shiny your truck is.
where did you get that little hose that goes into the waterpump
Old 09-17-2011, 01:31 AM   #12
ntd
thank you
does the long pump move the accessories further away with more clearance ?
Old 11-05-2011, 02:53 PM   #13
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
The long pump moves stuff towards the front of the rig as to getting more clearance with this set up I don't know about that...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
