Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 09-21-2011, 11:04 AM   #1
Str8-6-68
Str8-6-68's Avatar
New Member with a big project in the works
Hey guys I'm new to the chevy/gmc forum but my project truck is a 68 gmc long box 2wd. hopefully this project keeps me busy for a while as i want to shorten the frame for short box and swap front cross member for a 98.5 24valve 5.9 cummins turbo diesel with lots of work done, I was also thinking of closing in the open channel frame for a box frame. my goal for the motor is in the 800hp range give or take on a single turbo so I would love some feedback on some of the best rear end gears and axel shafts to use. I was thinking of doing a 2wd chevy 2500 front and rear 8 lug conversion including rear diff but i would rather keep as much off the 68 as i can except drum to disc and beefier suspension. any and all information on the suspension and rear diff to handle the added weight and high torque the engine will put out. Thank you in advance for all info.
-Allen
Str8-6-68 is offline   Reply With Quote
Old 09-21-2011, 01:51 PM   #2
1ATony
Re: New Member with a big project in the works
welcome to the site
1ATony is offline   Reply With Quote
Old 09-22-2011, 11:06 AM   #3
Str8-6-68
Str8-6-68's Avatar
thanks, anyone have some tips or advice on good rear end kits to handle the torque or would i have to swap out the rear end entirely?
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Old 09-22-2011, 03:29 PM   #4
luifer76
luifer76's Avatar
Welcome to the site.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 09-22-2011, 03:43 PM   #5
heeroyue2002
fat old dude
heeroyue2002's Avatar
welcome!
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 09-22-2011, 04:59 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
14bolt swap?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-23-2011, 10:45 AM   #7
Str8-6-68
Str8-6-68's Avatar
thanks everyone for the warm welcoming. 14 bolt rear end sounds decent i read one thread on it hopefully it will hold up cus it seems simple enough. would anyone think i would need to swap out the axle shafts also??
