09-28-2011, 08:17 PM | #1 |
[><]Sofa King Dirty 4x4[><]
Rebuild of my mini buggy
Day 1: Well as of now it has fresh green paint. the little 8 horse is going and its getting a chevette motor this weekend. tomorrow im getting some deck material so stay tuned
Day 2: Got the deck stripped down and got the materials have to set the water seal on and let it dry over night. heres a picture of how rotted it got Day 3: Its naked now Today : Got the 2 coats of water sealer done, now i got to do 2 more of primer. getting the motor thursday so hopefully all goes well Moved it under the carport, too hot to work
00' Chevy Silverado 1500 z71 33"s 3" lift 5-speed Past trucks 85' Chevy C10 Step side 388 stroker 33" bfg a/t's holley 670cfm world product heads 14.80@92mph 92' S10/Tahoe sbc swap |
09-29-2011, 10:06 PM | #2 |
Re: Rebuild of my mini buggy
10-01-2011, 08:01 PM | #3 |
Neat looking project. Looking forward to seeing the rest
10-01-2011, 11:54 PM | #4 |
Its mounted now have get a few parts and get the drive shaft cut will get pics int he mornin
10-02-2011, 03:34 PM | #5 |
got the motor mounted finally, yay
The axle got moved back alittle still have to get the drive shaft cut and rewelded. got to weld some gussets to the spring hanger in the rear. going to the junkyard on monday to get the rest of the motor parts i need and hopefully she'll be runnin this week i cant wait
10-02-2011, 04:22 PM | #6 |
BlahBlahBlah
What is thing crazy thing? Does it have a purpose?
10-02-2011, 05:19 PM | #7 |
The One And Only !!!
Neat little project !
How about some more pics and info on that square in the background of pic 5 ?
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
10-03-2011, 09:54 PM | #8 | |
Heres what the buggy looks like with the axle moved back
The shifter imma use Rear spring mount Some gauges i got today at the junk yard Its called a "Swamp Buggy" and the purpose for us floridians is so we can ride trails and go through mud and hunt and just have a good time on it Quote:
10-04-2011, 10:32 AM | #9 |
1965 Chevy C10, 2005 4.8L/4l60
Both are so cool man!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-04-2011, 03:33 PM | #10 |
Very cool!
"I feel the need for speed!"... as soon as I am done with my nap. |
10-04-2011, 06:04 PM | #11 |
Dude, That's one big ass truck right there !!!
I just noticed your here in Fl, You ever play at a place called Ocean Pond ?
10-04-2011, 06:28 PM | #12 |
No sir to far of a drive for me i play around my house and at the yacht club when they open
10-06-2011, 12:51 AM | #13 |
BlahBlahBlah
Oh, ok now I see. Its a mini version of those trucks that have the really narrow tall tires. Very cool. Should be fun to bomb around in.
10-07-2011, 01:50 PM | #14 |
Got a new starter and all the wires hooked up
Alternator hooked up along with the hydro pump Gas tank Battery hooked up Ignition and gauges hooked up Got to get another elbow for the exhaust Got to get the driveshaft cut It should be running this weekend, got to pull the carb off of bigfoot and throw it on to get it running then have to get the deck mounted and etc...
10-08-2011, 08:14 PM | #15 |
Got it runnin tonight runs and sounds amazing, got everything hooked up now i need an air cleaner and to throw the deck on. i can't thank my dad enough for helping hes the best
Homemade shift lever my dad came up works pretty great Radiator mocked up got to get some hoses Gas pedal hooked up
10-08-2011, 08:40 PM | #16 |
Look'n good !
Don't forget those action shots from in da hole......
10-08-2011, 08:46 PM | #17 |
Oh i wont , i can't wait to tear it up
10-08-2011, 09:32 PM | #18 |
10-09-2011, 03:53 PM | #19 |
Getting the deck fitted right now but the rain is trying to stop us.
Left to do: * Get radiator hoses and get them ran * Air cleaner * Mount deck * Mount seats * Mount and wire up the front lights * Tear up the nearest mud hole
10-11-2011, 03:31 PM | #20 |
Woohooo got some hose today for free now i can run the radiator. all that needs to be done is get the radiator situated weld the front two link bars mount the deck and seats and im done. should be running later today i will get a video
Lights mounted and wired The box that houses the air cleaner and the seat will sit on it
10-11-2011, 04:57 PM | #21 |
neat toy
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
10-11-2011, 08:12 PM | #22 |
Local Redneck Authority
Sweet toy you got there!
What is the rear axle out of?
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
10-11-2011, 08:18 PM | #23 |
Shootin to have it going wednesday
10-11-2011, 08:20 PM | #24 |
Cushman truckster look it up there weird little rigs. i call it a mini toploader
10-13-2011, 03:58 PM | #25 |
Now that it runs, looks like imma have to tear it back down unless it quits smokin cause it looks like the rings are bad =/ figures
But my solution is Got some goodies and now im broke, since the engine sat im hoping it only has a stuck valve so that can of restore will free any that are stuck.
