Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Closed Thread
Old 10-08-2011, 08:17 PM   #1
70BLAZERX2
70 2wd blazer going back together
I took it down for a motor swap..the 90 454 motor with TBI heads jusr sucked gas..4mpg..and it had to go..
I bought a 1990 454SS truck with a blown 350 in it for cheap..so i put the gas hog 454 in it,with a th400 and sold it..
Now its in with the 70 LS5 454 out of a chevelle..and a 5speed out of a 90 chevy truck..so it will be driven on the highway for those long trips..
70BLAZERX2 is offline
Old 10-10-2011, 12:37 PM   #2
CTENTA1
Registered 1971 K5
Re: 70 2wd blazer going back together
Nice.
CTENTA1 is offline
Old 10-10-2011, 02:02 PM   #3
SOON2BLAZE
SOON2BLAZE's Avatar
mmmmmm, big block
SOON2BLAZE is offline
Old 10-10-2011, 07:23 PM   #4
70BLAZERX2
got some more done today..driveshaft is in..I had one here the right length..45.5 inches..
I also used the 90 trans crossmember and had to drop the trans mount down 1/2 inch (due to being lowered to the ground)
also had to cut out floor pan for large bolt on hump...but it was easy..
wont be long now..a few more hours and it will be alive again.
I got the big block 67-71 mounts at knoxville pullapart for $8.00 lol
it had a 460 ford motor shoved under the hood of a 71 truck..I found a driveshaft and moved that motor and got them out..best part i ever found there
Nothing like a big block...then a LS5 with stock gm domed pistons. (std bore) .and a few mods to get 450 hp out of it..
Old 10-12-2011, 08:48 AM   #5
99-LS1-SS
99-LS1-SS's Avatar
Did you move the motor forward or to the big block mounts put it in the right place?
99-LS1-SS is offline
Old 10-12-2011, 12:39 PM   #6
70BLAZERX2
motor is set to the rear..big block mounts go in the rear lower holes..just as it would be in a truck.
I will be getting more pics soon...the NV3500 1990 5speed was a little big heights wise,has to go to large floor hump..
now i can run a fan shroud thats its in stock location.
Old 10-14-2011, 04:35 PM   #7
99-LS1-SS
99-LS1-SS's Avatar
Did you drill holes into the cross member for the front lower mounting position or did you only use the rear holes?
Old 10-14-2011, 08:01 PM   #8
70BLAZERX2
i did not drill holes..the rear 2 top holes and the rear lower 2 holes..the 67-71 big block mounts bolt right up..
I used small block 67-72 mounts with 2 small block crank bolt washers and they worked just fine.
you can get the 67-71 big block rubber mounts but they are pricey.
More pics over the weekend as i am about to fire it up and drive it out.
clutch line and clutch master cyl. need to be made..and exhaust fixed..then its ready.
Old 12-03-2011, 10:58 PM   #9
PHAT TONY
PHAT TONY's Avatar
...more.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline
Old 12-04-2011, 06:17 PM   #10
70BLAZERX2
Originally Posted by PHAT TONY View Post
...more.
Blazer got pushed back off the lift for now...It will be getting more work done...with plenty of pics...
I wish i could have it done now..but I have plenty of other cars and trucks to work on ...I have to pay bills...1st...
Closed Thread
