Old 10-20-2011, 06:30 PM   #1
litebulblsc
litebulblsc's Avatar
12, really?
I just bought a 2000 Silverado 1500 with the 4.8l. Ran my first tank of gas through it and crunched the numbers to see that it only gets 12 miles to the gallon? 85% of my driving was expressway.
So any one have any ideas of what I can do to improve it? I would like to get it to 15mpg which shouldn't be asking to much I think.
Thanks,
Josh
litebulblsc is online now   Reply With Quote
Old 10-20-2011, 09:07 PM   #2
gregory5000
Re: 12, really?
It sounds like there is something wrong with your truck. My 2001 4.8 with 140k miles gets 18 MPG on a bad day. The best I have gotten is 24. The average is 20. What RPM's are you turning at 55? I am turning 1500 rpm's with a 3.23 rear ratio and mine is 2wd.
2001 GMC 2WD, 1998 Chevy K2500
gregory5000 is offline   Reply With Quote
Old 10-20-2011, 09:14 PM   #3
litebulblsc
Re: 12, really?
I am not sure on engine RPMs. I should mention that I drive 75-80 MPH depending on the traffic.
Old 10-21-2011, 01:32 AM   #4
1990SSchevy65
1990SSchevy65's Avatar
Re: 12, really?
Ummm...you definitely have something going on. I have a 2003 CCSB 4x4 with a 6.0, 3.73 rear end and get 12-14mpg, but I only drive about 5 over. Driving that much over the limit does get you to places faster, but you are running higher RPMs which will eat up more gas to run the truck.
2003 Chevrolet CCSB 4x4 1500HD Mine
2011 Toyota Corolla S Wife's new ride
2002 Pontiac Grand Am SE2 Wrecked/Totaled 2014
1990 Chevrolet 454SS GONE 02/26/11
1991 S10 SCSB GONE 12/24/08
1965 Chevrolet LB GONE 06/06/05
GM for life
1990SSchevy65 is offline   Reply With Quote
Old 10-21-2011, 10:29 AM   #5
gregory5000
Re: 12, really?
I just got back from a road trip to the smokey mountains. I filled up at home, drove 200 miles at 70-80 on the interstate and then drove 150 miles in town at the area cities. That 150 miles was 3 days of mountain and stop and go traffic. I got 19 on that tank.
Old 10-21-2011, 10:38 AM   #6
Warrens69GMC
Warrens69GMC's Avatar
Re: 12, really?
need more info: 2wd/4wd, what "extras" are you carrying (tools, equipment, passengers) and is there a lift on the truck? What size tires?
Old 10-21-2011, 10:49 AM   #7
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: 12, really?
Sounds like something is wrong for sure. Do you have a SES light on? Make sure it isn't just a light burned out also, it should come on when you turn the switch on before cranking. A common failure is the knock sensors get wet and corrode, resulting in the engine going into limp mode making it retard the timing severely which can kill the fuel mileage and power. Bad o2 sensors can cause it to run rich also killing fuel mileage, or clogged cats.
That definitely doesn't help your mileage as mileage starts dropping off fast above 65, but still it shouldn't be getting 12.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 10-21-2011, 03:29 PM   #8
biggsteve97
Re: 12, really?
I have a 2002 Silverado 1/2ton 4x4 with the 4.8L and even with a full tool box (approximately 150lbs) Stock I got 18-19 hwy roughly 14-15 city. With the dynomax Ultra-flo exhaust, throttle body spacer, and cold air kit I now get 16-17 city and 21-23 hwy. I have seen as high as 25 hwy but have not been able to duplicate more than once.
my 03 Z71 Tahoe stock was 11 city 16 hwy now with the headers, Dynomax kit, cold air kit, throttle body spacer I get 15-16 city and 21-23 hwy. combined I average 18 mpg most tanks now where stock was a mere 13.5mpg combined.
biggsteve97 is offline   Reply With Quote
Old 10-21-2011, 06:00 PM   #9
litebulblsc
Re: 12, really?
I know driving that fast will lower my mpg. That is why I would be happy with around 15mpg. Lift is still sitting in the house, tires are stock, it is 4x4, automatic, extended cab, short bed.
One day I had two passengers the other 3 I was alone. Just carry a small 1/4'' drive tool set so maybe 10lbs there. SES light works and is never on. Tires are inflated to 35psig.
It needs shocks, but that shouldn't hurt my mileage...
I am unsure of the rear axle gearing too
Old 10-21-2011, 07:55 PM   #10
Lee H
Lee H's Avatar
Re: 12, really?
The number one cause for reduced mileage (not including driver) is O2 sensor. Sounds like its time to change it/them out.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-21-2011, 10:37 PM   #11
crazy longhorn
Fabricate till you "puke"
Re: 12, really?
My 02 silverado (extended ,2wd), is consistant @ 13.7 in town/18-19 on the hyway. This is also a 4.8, with 162,000 rounds on the clock. On the hyway, I run 70-72(seems to be the sweet spot), & the old gal is bone stock....albut a 14" body Magnaflow added to the stock system. I have noticed however , when running 78-82 mph, the mileage sucks crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-23-2011, 08:45 PM   #12
litebulblsc
Re: 12, really?
Does anyone besides magnaflow make a replacement y-pipe? Mine is all beat up and probably wouldn't hurt to replace the cats.
Old 10-24-2011, 08:18 AM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
Re: 12, really?
Yeah, something definitely wrong, my 5.3L 4x4 has never gotten below 13mpg in winter with 100% city driving (unless I needed to use 4x4 which is rare down here). Towing my boat drops it to 11, but unloaded it's normally 14 around town and 17.5-18 on the highway @ ~ 70. I've been told that cats and o2 sensors will always throw a code on these trucks if they're bad, but I can't verify that 100%, but considering there are 2 cats and 4 O2 sensers (at least on the 5.3 there is, I'm assuming hte 4.8 is the same) I think I'd have someone check it out first.
I would try a full tank of "slowing down" to 70 if you can. Also, if your doing a lot of high speed weaving/passing dropping it down to 3rd will eat fuel mileage too. Might be something to try before throwing $ at it.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-24-2011, 03:34 PM   #14
litebulblsc
Re: 12, really?
I hold a constant 80 so it is always in overdrive. This tank is seeming better, but it is hard to tell for sure because of the sketchy gas gauge. I poured some Lucas fuel cleaner in it just in case it actually does something. Got my leveling kit on it yesterday along with new shocks. Drives a lot better now.
Old 10-25-2011, 07:57 PM   #15
litebulblsc
Re: 12, really?
Up to 14.4 mpg on the second tank
Old 10-26-2011, 04:25 PM   #16
Dustin07
Stirrer of the Pot
Re: 12, really?
yeah I was getting 20+ on my 99 4.8L ext cab 1500. always a min of 18, well over 20-23 on hwy driving.
Dustin07 is offline   Reply With Quote
