Old 10-24-2011, 02:22 PM   #1
Tjfabs
72 two wheeldrive conversion
I have a1972 chevy two wheel drive truck that I want to turn into a fourwheel drive truck, does anyone know what I need to do about putting leaf springs in and getting the front axel in straight thanks for the help.
Tjfabs is offline   Reply With Quote
Old 10-24-2011, 04:04 PM   #2
va72longhorn
va72longhorn's Avatar
Re: 72 two wheeldrive conversion
I know the frames are different on the front as the four wheel drives have an "offset" for the axle travel. You may want to move this to the 67-72 specific forum and Im sure a bunch can offer advice. My advice would be to find an old cancer ridden 4X truck and recycle the frame.
va72longhorn is offline   Reply With Quote
Old 10-27-2011, 09:39 PM   #3
Tzagi
If you are planing on running a lift anyway,
the frame design is not a major issue
Here is where you need to search:
http://www.pirate4x4.com/forum/forumdisplay.php?f=17
Hint:
you need to be a paying member to search on PBB, to bypass that go to Google,
Click advance search and fill the fields
what you are searching for is SAS, or straight axle conversion, or swap.
Just a sample:
http://search.yahoo.com/search;_ylt=...2=sp-qrw-corr-
Tzagi is offline   Reply With Quote
