Old 10-27-2011, 11:18 AM   #1
chevy355
14 bolt disc brake
I want to do a disc brake conversion on my 14FF rear end. The kit i found takes 3/4 ton front disc's and calipers. My worry is i would have no E-brake. Is there any way to have a E-brake on a disc brake set up? Thanks, Matt
Matt
1986 chevy K10 355, sm465/np208, 14FF/dana 44
1984 chevy K20 350, th400/np208, 14SF/10 bolt
chevy355 is offline   Reply With Quote
Old 10-27-2011, 01:50 PM   #2
blazin71K5
blazin71K5's Avatar
Re: 14 bolt disc brake
rear calipers from a 78 cadillac eldorado will work.
good luck on your build.
71 2wd k5
67 Nova
blazin71K5 is offline   Reply With Quote
Old 10-27-2011, 08:33 PM   #3
wyattglock
wyattglock's Avatar
Dont know where you found the disc conversion kit, but www.diy4x.com has a lot of those kits. Just an fyi! Good luck on your project.
wyattglock is offline   Reply With Quote
Old 10-27-2011, 11:35 PM   #4
595sparky
Doing one on my 78 3/4 ton. Bought the brackets from ORD and roters are the same as on the front as well as the calipers. im going to use a E brake that mounts on the tail shaft of the transfer case. mine is going together ok so far.
595sparky is offline   Reply With Quote
14 bolt, disc brakes, e- brake
