10-30-2011, 06:32 PM | #1 |
tranfer case model
Hello friends
I drive a 1500 2003 chevy extended cab 4wd whats model its my tranfer case? there;not tags o identificacion plate but a have the round button auto,4lo,4hi,2w i asume have the autotrac sistem but i tried to do an oil change for tranfer case and found red oil like transmision fluid i drive my last car was a 1500 4wd chevy pickuo 2001 and use a blue color transfer case fluid my question is i have a diferent model tranfer case? o somebody mess out my truck? I have two month old with this truck |
10-30-2011, 08:21 PM | #2 |
Re: tranfer case model
most of the t-cases use the new dexron 5 on chevys,
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-30-2011, 09:58 PM | #3 |
NVG 149-NP3 Manual Transmission Fluid GM P/N 88861800
NVG 246-NP8 Auto-Trak II, transfer case fluid, GM P/N 88900402 NVG 261-NP2 Manual Transmission Fluid GM P/N 88861800 NVG 263-NP1 Manual Transmission Fluid GM P/N 88861800 If you have a Auto-Trak use the GM Fluid, All other transfer cases use Dexron III. Since "Money Hungry" GM introduced Dexron IV, Dexron III is being phased out as a product name. It was renamed Manual Transmission Fluid part # 88861800 DO NOT use Dexron VI in place of Dexron III/manual transmission fluid in any manual transmissions or transfer cases that specify Dexron III, as a failure may result. NP1, NP2, NP3 & NP8 are RPO codes......Look in your gloveblox & know for sure what case you have |
10-31-2011, 02:27 PM | #4 | |
10-31-2011, 05:19 PM | #5 |
crap wish i had known that when we did the 100k on our 03 s-10 zr2 the dealer told us to fill the tcase with dexron vi
