Old 11-13-2011, 06:58 PM   #1
bnb0221
Temp problem
I just got a 05 sub with a 5.3. The temp gos way past the 260 mark but it don't seem hot at the motor and it's not boiling over so I replaced the temp sending unit and it still does it can anybody help
bnb0221 is offline   Reply With Quote
Old 11-14-2011, 08:36 PM   #2
clinebarger
Re: Temp problem
The stepper motor in the insterment cluster is most likely bad, Easy to check with a scanner that can access the cluster (IPC), If the data stream is reading normal temp the cluster is bad. Rebuild or replace the cluster.
clinebarger is offline   Reply With Quote
Old 11-15-2011, 10:17 AM   #3
bnb0221
Re: Temp problem
ok thanks ill check into that
