11-16-2011, 01:13 PM | #1 |
Bag position??
So what is better, bag over axle, in front, or behind axle. I see alot of guys running different setups and want to know what the difference is. Im running a step notch and trailing arms. Would really appreciate some advice before i go welding. Thanks
11-16-2011, 03:45 PM | #2 |
Re: Bag position??
A lot depends on how low you want to go. If you want to go lower than the 4.5" between the trailing arm and the frame then you will have to go over the axle or behind it. that will gain you an additional 4.5" of drop, but your front end and what stance you want will determine what you need. If you add 2x2" drop blocks between your trailing arm and rear axle you may be able to live with placing the bag in the stock coil spring location. Kieth
11-16-2011, 04:04 PM | #3 | |
Re: Bag position??
11-16-2011, 04:29 PM | #4 |
Re: Bag position??
It all depends on what you use your truck for.
Placing the bag directly over the axle is the strongest and is what I recommend for any truck that tows. If you put the bag behind the axle you can drop farther, but the weight of the truck is essentially trying to "twist" the axle out of its mounts, and will wear your 4 link or trailing arms faster. If you put the bag on a link or trailing arm, you can gain travel but decrease how much weight the bag can support. This also accelerates the wear on the links too. |
11-16-2011, 07:03 PM | #5 |
Re: Bag position??
Sorry should have been more specific but it's a 72 I'm working on. And their won't be any towing done, but it does have a mild big block but just for cruising. I already have the over the axle mounts, are their any draw backs to those?
Posted via Mobile Device |
11-16-2011, 07:14 PM | #6 |
Re: Bag position??
They take up more real estate above the rear end housing which can infringe on bed space.
11-16-2011, 07:28 PM | #7 |
Re: Bag position??
How low do you want your truck to be? Are you notching the frame?
11-16-2011, 10:28 PM | #8 |
Re: Bag position??
Yes it the frame is already step noched, so there should be no bed clearance issues since a big chunk has to come out anyways.
11-16-2011, 10:36 PM | #9 |
Re: Bag position??
Since it's already step notched & you have the 'over the axle' mounts, run them w/a rolling sleeve style bag (Firestone F9000 series).
11-17-2011, 12:01 PM | #10 |
Re: Bag position??
Well i already have ss-7 bags to.
11-17-2011, 12:05 PM | #11 |
needs more $$$
Re: Bag position??
The problem you're going to have with using these bags on top of the axel is ride quality. They will work just fine, but the rolling sleeve bag will provide a better ride and usually that's a big deal to most since one of the big advantages of a air ride system is the ride quality.
Got any pics of the suspension?
1970 2wd Blazer |
11-18-2011, 11:51 AM | #12 |
Re: Bag position??
Ya ive been reading around and i think i am gonna hafta get some sleeve bags for the back. But i also have slams for the front to. Ive heard its not good to run different bags like that. Will it be bad to run slams on front and sleeves out back?
And sorry no pics yet. Just a rusty frame with a bad a$$ pb crossmember and trailing arms and qar notch with no bridge yet. |
11-18-2011, 12:03 PM | #13 |
needs more $$$
Re: Bag position??
Not at all...it's done all the time. If you have a full blown Porterbuilt front and rear ride, you'd be running convoluted bags (like the slams) up front and a sleeve bag (like the firestones) out back. Good luck with the build and start taking/posting some pics!
1970 2wd Blazer |
11-18-2011, 12:08 PM | #14 | |
Re: Bag position??
