What rearend????
I am need of a rearend for my 69! It will be layed out and bd to lay pinch welds.
I need to know what my best route would be. I am currently 6 lug but I am not against swapping to 5. I was wondering about the Caprices. I think I need something a little narrower than stock. thanks Brad W |
Re: What rearend????
as far as what u need// need info on engine power you are planning a 200hp or 600hp engine will need differnt strengths to live// as far as width need info on rims with backspace etc
Forgot about that. I have a mild 350, with a 700r4 behid it. This is going to be a cruiser not a racer. I was wonder about Caprices, Regal, S-10's. Anything I can pick up easily at a Pull-a-part.
the s10 and g body but for the grand national and 442 used a 7.5 10 bolt which is kinda weak.I would be looking for a 10 or 12 bolt from a truck you'll have to change the spring perches but that's not hard.
what model trucks. I would like to find one that I will not have to narrow.
Would a 73-87 rearend fit? or are they wider?
1 1/2" wider.......seems like, somebody else will confirm or not.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
Do you have a rear end in the truck now?
No, I do not have a rearend.
Does anyone know how wide the stock rear end is so he can have a idea what to look for?
I believe stock width is 60.5" I am looking to something close to that. But strong enough to hold up to my motor. It isnt going to be a race car but I dont want it to take a dump on me at a stop light.
Here's some info on a 71 rear which is an 1 1/2" wider than the 70 down.
http://67-72chevytrucks.com/vboard/s...d.php?t=440869
#13 |
Don't overlook the 8.8" rear out of a Fox body Mustang....
Easy to find. Used housings can be found already beefed up. Strong ((falls between the 10 & 12 bolt in strength). Huge aftermarket support. Disc brake kits & 5-lug axles readily available.
#14 |
HERE IS A USEFUL CHART
http://www.carnut.com/specs/rear.html just for info we build rear ends to any width and any HP starting at $1000.00 |
#15 |
Scoti the 8.8 from a explorer is used for a alot of swaps early mustangs and some jeeps.
#16 |
True, but I recall the axle tubes are differing lengths & the overall width is wider vs. the Fox body stang. I think guys typically shorten the longer side to equal the shorter side for a cheap-ish alternative. I don't remember what the diff was in widths between the 2.
#17 |
The explorer is wider then the mustangs like a inch or two but its 31 spline and most are a factory lsd too.They do have a off center diff which can be fixed like you said shorten the one side.
#18 |
![]() ![]() Join Date: Jan 2011
67-68 is 55.5" plate to plate. Some early 69's
69-72 is 57" plate to plate. or, the WMS measurement if you prefer. Find an early rear end housing and you can run a wheel with .75" less Backspacing (looks wider / more lip)
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#19 | |
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#20 |
![]() Join Date: Jul 2010
I might have one out of a 68'. I'll check tomorrow. Its yours if it will work.
DeWayne
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
