Old 12-10-2011, 03:14 PM   #1
77chevyinline6
77chevyinline6's Avatar
Question First truck need ideas people
This is my first truck 77 chevy inline 6 2wd 125000 miles the only things i have done to it so far is billet grille glasspack exhaust pyle shaft style radio(i didnt want to ruin my dash) a 400w amp and 2 12 inch subs. im debating whether to lower it or not but the biggest issue is the motor. i havent decided whether to beef up the inline 6 or do a small block v8 swap like a 305 i drive this truck everyday so i cant do a big block due to gas milage. do any of yall have any inline 6s? whats your mpg and how fast is it? because mine drinks gas and it pretty slow
77chevyinline6 is offline   Reply With Quote
Old 12-10-2011, 03:30 PM   #2
J Knight
J Knight's Avatar
Re: First truck need ideas people
Great lookin truck. Find a good stock 350 to put in it.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 12-10-2011, 03:35 PM   #3
77chevyinline6
thats what i was thinking, but its a 3 on the tree would i have to switch transmissions also? and thanks i like yours alot what size drop is that?
Old 12-10-2011, 04:19 PM   #4
sethv
sethv's Avatar
I think the bellhousing and everything are the same so you could put a 350 and keep the 3 on the tree.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 12-10-2011, 04:20 PM   #5
77chevyinline6
Thats what i would rather do because i mean you know 3 on the trees are just too much fun
Old 12-10-2011, 04:25 PM   #6
notyo_cheez
Get a 4bbl Offenhauser intake and 390 cfm carb from jcwhitney.com, keep the 6.
Nice truck, wish mine was that clean.
notyo_cheez is offline   Reply With Quote
Old 12-10-2011, 04:26 PM   #7
77chevyinline6
how many mpg do you think i would get with that setup?
Old 12-10-2011, 04:34 PM   #8
notyo_cheez
Not sure but it won't be nearly as much as a V8. The I6 and 2bbl 305 were within 2-3 mpg on EPA estimate window stickers back in the day if I'm not mistaken, and I probably am mistaken if someone will correct me?
If you're using a lot of fuel might want to look at a few things, like a tune-up and check your fuel pump? Check your oil and smell the dipstick. You might be leaking a little if you smell gas...
Old 12-10-2011, 04:36 PM   #9
77chevyinline6
thanks ill do that, i need as much mpg as i can cause right now im using a tank of gas a week just going to school and back about 10 miles a day
Old 12-10-2011, 06:41 PM   #10
Stepper86
Stepper86's Avatar
Keep the six, they are cool. I have a 305 in mine, sure it runs okey for what it is and sounds like a v8 should. But mpg/performance........ no, not worth it in my opinion.
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 12-10-2011, 07:02 PM   #11
77chevyinline6
yeah i like the 6 too because no body has them
Old 12-10-2011, 11:06 PM   #12
MCCLELLAN103
MCCLELLAN103's Avatar
That thing is clean just leave it alone and drive it
To Broke to be Fast
MCCLELLAN103 is offline   Reply With Quote
Old 12-10-2011, 11:32 PM   #13
77chevyinline6
whats wierd about this truck though its the motor is not original nor is the windsheild im starting to wonder if its been wrecked?
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor)
350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator.
Old 12-10-2011, 11:59 PM   #14
ivorton74
ivorton74's Avatar
i say just keep the six...i think they are pretty kool. if u want more power some headers and exhaust would free some horses. also switch to a 4bbl carb will work too for power but you're look to improve fuel economy so maybe just stick with the 2bbl. love ur truck btw and the 3 on the tree is kool.
ivorton74 is offline   Reply With Quote
Old 12-11-2011, 12:00 AM   #15
77chevyinline6
it has a factory one barrel in order to get a 2 or 4 bbl you have to get a aftermarket intake, and to get headers you have to get a aftermarket intake on a inline 6 because the manifolds heat up the carb when its cold or something like that
Old 12-11-2011, 12:04 AM   #16
undr8ed
I've got a 250L and 3-on-the-tree... I rebuilt the carb and got as much vacuum I could playing with the distributor. It's not going to win many races, but it should be right around 18mpg +/- but I'm also running 225 tires, so my rpm's are probably a little higher than they would be with a stock tire.
There are a TON of things you can do to get more from that engine. I say keep it
riding... just riding.......
undr8ed is offline   Reply With Quote
Old 12-11-2011, 12:06 AM   #17
77chevyinline6
yeah itb be easier to just do stuff to the motor but how many mpg would i loose with a mild cam?
Old 12-11-2011, 12:16 AM   #18
undr8ed
Cheap
Fast
Reliable
You only get to pick 2 lol
You could cam, lump port the head, 2 or 4 barrel it, find a 292 to do the same with, but in the end, it's all gonna be $$$ If you work to fine tune the one you have, you can build another to drop in when you're ready. That would probably be your least expensive way to go about it...
Of course, it all depends on what you want in the end.......
Old 12-11-2011, 12:20 AM   #19
77chevyinline6
i need it to be fast and somewhat good on gas because its my daily driver
Old 12-11-2011, 12:28 AM   #20
gGMC DOG
take a look at this site. may give you some ideas of what you can do to that 6 http://www.jalopyjournal.com/forum/s...=242039&page=8
gGMC DOG is offline   Reply With Quote
Old 12-11-2011, 12:44 AM   #21
77chevyinline6
thanks man
Old 12-11-2011, 01:03 AM   #22
BIG10
BIG10's Avatar
Very clean truck. I like it. Keep the 6. It's never going to be "fast", but with a tune up and some carb maintenance it should get you to school just fine. If you want fast AND mpg you're looking in the wrong place, you need a super turbo-injected fuel-charged import with a very large wing. Your truck is cool enough as it is, it doesn't need to be fast.
Jay
1978 Big 10 Silverado, 355 + 700R4 + 3.42 + factory tach + A/C + dual tanks + working cruise control = awesome highway cruiser.
BIG10 is offline   Reply With Quote
Old 12-11-2011, 01:05 AM   #23
77chevyinline6
lol thats hilarious man^
Old 12-11-2011, 03:57 AM   #24
andrewmp6
A diesel swap can be fast and still get good mpg for a truck.I have owned a import or two fast ones are hard on fuel trust me lol.
andrewmp6 is offline   Reply With Quote
Old 12-12-2011, 06:57 AM   #25
D13
D13's Avatar
Option 1 - drive that thing to Michigan and give it to me.
Option 2 - Carefully inspect the motor to see if it's an integral head (the head and the intake are one casting). Easy way to tell, the head bolts run up and down, if there are not bolts and clamps runnning cross car to hold on the intake, it's integral head. There are NO itake and carb packages available for this, you would need to replace the head to upgrade. In that case, see option 1, or just give it a mild tune up and be happy. You should be able to get 18+MPG (warning - MPG is directly related to right foot pressure).
Option 3 - put in a mild cam and new lifters, get the velves done at the same time. A little more HP, no real change in mileage. Would run ~$400 if you do it yourself.
Option 4- Change to non-integral head, add intake and small 4bbl carb. Power up MPG down. ~$1000
Option 5 - option 4 + option 3 = much more fun to drive but ~$1500
Option 6 - check your rear end ratio, either with the SPID or by checking the rear. Most likely it's 2.73. You could swap in a 3.08 and and add an overdrive trans, either a late model 5 speed or an A-833. 5 speed gets you better MPG and performance. ~$800
Option 7 - all of the above, 20MPG and fun to drive, ~$3000 (you did rebuild the motor too, right?)
Option 8 - stick in the 350. ~$1500 for a basic swap, need to upgrade radiator, be sure you get ALL the brackets. MPG goes down ~3-5 if you can keep your foot out of it (good luck with that). If you swap in the 5 speed too then you might get back close to stock, except it'll be so much funt that your fott will be on the floor again....
ps sending you a PM, wonder if you could do me a favor...
Don't even think about the diesel unless someone gives you a complete running truck. EVERYTHING needs to be swapped except the trans and I don't think you'll like a 3 speed manual diesel.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
inline 6 chevy c10
