..4-link??? help!
hey guys...i've decided to go with a flip kit out back on my 82 swb and i'm at a bit of a stumbling block. this is where i'm hoping you guys can come in and shed some light: i've been doing much research and have noticed many 4-link setups being run, whether bagged or static dropped. i know a 4-link setup is is designed to prevent/limit axle roll...but is it CRITICAL/NECESSARY to do so when flipping the axle on top? or is it more of an added precaution? any help/advice you can offer is much appreciated...
#2 | |
Re: ..4-link??? help!
If you flip the rear above the springs, it has the same axle roll as when it was below the springs because the rate doesn't change. If you're ok w/the set-up in its present state, you'll be fine once it's flipped. If the plan is big power or a better ride w/air bags & eliminating the leafs, the 4-bar or a truck-arm system would be the way to go.
GoatLube Experss
![]() Join Date: Oct 2009
the big'st reason people are do'n the 4 link with bags is the amount of lift/drop you can achive and the adjustability they offer, some put the bag's on the top link bar and get alot more lift and a smoth'r ride.
if you'r not plan'n to slam the truck the flip kit on your exsist'n leaf spring's will be fine.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
Tags |
4 link, rear end setup, suspension |
