01-04-2012, 10:57 PM | #1 |
Is any body familiar with a chevy 292 with a 3 Speed on the tree?
Hi there.... i recently bought a 71 c10 with a 292 and a 3 on the tree transmission.(with no tach) I notice that when i shift from 1st to 2nd or or 2nd to 3rd that the rpms are too low to meet the proceeding gear. I now bring my engine to a way high rpm ( i can tell because of the way she feels and sounds) and then shift.
I would like to know if this is normal for my kind of set up or maybe i have a serious problem. Thanks Rhy |
01-05-2012, 05:24 PM | #2 |
Re: Is any body familiar with a chevy 292 with a 3 Speed on the tree?
I dont quite understand the question but there is a wide split in the ratios on those old trans. It sounds like it is normal. You have to get the feel of it & tailor the engine speed to match the next gear.
01-06-2012, 03:07 AM | #3 |
I have the SM 465 floor shift behind my 292, but with the granny gear, you hardly ever use 1st. I usually shift at about 2000-2500 RPM between gears. 292s tend to lope low.
01-06-2012, 10:55 AM | #4 | ||
"I ain't nobody, dork."
All 3 on the tree rigs I have ever owned or driven have that same rpm split. There's only 3 gears. If it weren't that way... you'd be cruising at 4,500 rpm at 60mph.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
01-06-2012, 08:01 PM | #5 |
Thanks guy...it makes me feel a lil better.
Tags |
292, 3 on the tree, 3-speed, shifting problems |
