Old 02-03-2012, 04:23 PM   #1
deathlinx
deathlinx's Avatar
69 C10 Steering Column
i have a 69 C10. i want to remove the steering column to do some restorations. but i am currently un sure how to do so. if there is anyone that could provide me with instructions of how to do this it would help out my weekend a lot.
thank you
1969 Chevy C10 396
deathlinx is offline   Reply With Quote
Old 02-03-2012, 04:36 PM   #2
no moa
no moa's Avatar
Re: 69 C10 Steering Column
Disconnect the column from the steering shaft, i just removed the bolt at the upper joint, and hammered it off, it comes off hard.
Remove the pin holding the shift rod to the column (assuming its an auto)
Remove the screws and bolts holding the column to the dash, there is a plate with 2 phillips screws, then remove the 1/2 bolts from the bottom of the plate.
There are 2 1/2 bolts at an angle that need to be removed to drop the column.
There is a plate at the firewall that has 2 5/16 screws, remove those.
Unhook the wiring at the top of the column behind the dash, and at the bottom of the column at the firewall.
I think that is all, i removed mine from the same truck 69 396 yesterday.
I think thats all i did. Take it slow, dont force it (except the joint to seperate the column and the shaft) and keep the bolts together, took me less than a 1/2 hour.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 02-03-2012, 04:56 PM   #3
deathlinx
deathlinx's Avatar
ok thank you i will take a look. i am/was confused cause when i looked into the engine comp at the steering rod and bolts there are 3 different bolts. 1 all by its self and 2 more just a little above it that are close together. im not sure of which bolt(s) you are refering to...i will upload picture in just a minute for better reference. and yes it is an auto and 396 just as yours. so i hope you understand what i am saying
1969 Chevy C10 396
Old 02-03-2012, 05:04 PM   #4
deathlinx
deathlinx's Avatar
ok taking a closer look there are 5 bolts...they are circled in RED. which of these am i taking off and out to be able to pull the column out after i disconnect plug and undo the dash and firewall brackets
1969 Chevy C10 396
Old 02-04-2012, 11:14 AM   #5
no moa
no moa's Avatar
i did the bottom one, where the splines slide into that joint on the end of the shaft. Soak the sheet out of it with PB blaster, it will help.
Old 05-31-2013, 09:14 PM   #6
Jeromy93
On the bottom of the picture what is that whole piece called?
Jeromy93 is offline   Reply With Quote
Old 05-31-2013, 10:23 PM   #7
SS Tim
SS Tim's Avatar
If you don't have them, download the service manuals here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
help me, steering column
