Old 02-13-2012, 05:00 PM   #1
willywoo28
$$$million dollar oil pan "?"
Okay, so i have been doing quite a bit of research, losing whats left omy hair trying to figure out if i can replace my oil pan gasket w/o removing the motor.... I have a 1979 c20 w/ a 350 & 400 tranny. There appears to be enough room, but i dont want to start a 90 mon project and turn it into an all day job. Anyone know if this is possible?
willywoo28 is offline   Reply With Quote
Old 02-13-2012, 05:49 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: $$$million dollar oil pan "?"
I did it on my old 74 c10. Just had to hand turn the crank a few times to get the pan to clear it as I removed/installed it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-13-2012, 06:39 PM   #3
Dalaigh
Canadian Trucker
Dalaigh's Avatar
I've done several oil pans and have never run into any problems. But if a clearance problem arises, do like BLE' BURBAN said or at worst if you have an engine picker, just pull the engine mount bolts and lift the engine an inch or two. But it really shouldn't come to that.
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 02-13-2012, 08:12 PM   #4
Wrecked1982
Wrecked1982's Avatar
i did it and jacked the engine about two inch like dalaigh said and it went pretty well
Wrecked1982 is offline   Reply With Quote
Old 02-13-2012, 08:51 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
in the old days when i did this without a hoist id undo the motor mount bolts and jack up the motor from the oil pan with a floor jack with a piece of wood on it.. then id stick a couple of chunks of wood between the motor mount on the block and its perch on the frame to give it room and was able to redo the oil pan that way... always replaced the pump while i was at it too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-13-2012, 09:00 PM   #6
meter swinger
meter swinger's Avatar
i've done it this way also. however now that i have a tranny shop that will do oil, gasket and filter for 65$ i dont plan on doing it again
meter swinger is offline   Reply With Quote
Old 02-13-2012, 11:15 PM   #7
willywoo28
Thank you all very much for the quick replies. I appreciate teh experience and the advice. I feel well prepared for hopefully a quick turn around, and hopefully a fun weekend.
Hey any of you going to the winternationals here in Phoenix this weekend?
Take care!
Will
Old 02-14-2012, 11:15 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
yup lifting it up makes it easier
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-14-2012, 01:22 PM   #9
irishman999
irishman999's Avatar
Take care!
Will
damn dude, I wish I didn't read that! Last time I got to go was in 07.....
irishman999 is offline   Reply With Quote
Old 02-14-2012, 01:39 PM   #10
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Take the fan shroud lose first . A couple of short 2"x 2"s . Spend the extra money on the one piece silicone pan gasket , That's a gift from above . Just did this very thing a couple of months back in a c30 .
powerdriver 1958 is offline   Reply With Quote
Old 02-14-2012, 03:35 PM   #11
dugvera@gmail.com
dugvera@gmail.com's Avatar
I second the one piece pan gasket.
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
Old 02-18-2012, 11:54 PM   #12
willywoo28
So the project is done.... something special though. I found out that the block is a 4bolt main.... the inside of the pan was practically spotless, and the pistons were upgraded at some point! This thing is cherry inside the block. I am just really excited that it is a 4bolt main.....
Thank you all for your suggestions. The job went seamlessly, and i appreciate all of gour experience and expertise.
Willy
