87 V30, front springs or Air Lift or both?
I have a 1987 V30, 454, th400, np205, 77k mi. It is a clean, clean, clean old truck. I have decided against installing 2.5" or 4" Skyjacker lift kit for the sole fact that the new springs provided with the lift kit are only 2.5" wide, and the factory OEM springs are 3" wide. Now, anyone knows that less spring mass = less capacity. I do not plow or have a heavy front bumper, but there is the big block in there. I called Skyjacker and they confirmed that with any of their springs (even the fitted ones), there would be a reduction in capacity. To me, thats no good.
I want to raise the truck in the front to level it, but not so much as to have it looking like it is constantly driving up hill. So, I looked and searched for a quality Add-a-leaf for the front. I found 1 such place. That place is called Husky Springs. Adding a 4th spring to the bottom of the leaf pack would raise the front a little?. Here is a link to the spring I am looking at. https://huskyspring.3dcartstores.com...ps_p_1865.html The other option I found was Air Lift products. The inflatable bags for the front of the truck. The truck would probably ride even rougher than it does now, but, the system installed with a tank and compressor, is adjustable. Here is the link. http://shop.airliftcompany.com/produ...de_Control_Kit What is anyones experience with either of these products? What are the opinions of installing both? Or Should I just order a new 4 leaf pack for each side that are made to OEM spec? Any advice will solve my great debate. thank you!
1985 GMC K2500. 350/TH400/208. 4:10's. stock. 1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD. |
It followed me home?
Re: 87 V30, front springs or Air Lift or both?
Off road design makes a 1" zero rate for the front too
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Great websight. I will consider this option. Thanks!
Tags |
add a leaf, air lift, front level, k30, v30 |
